I am setting up a clock on my tft display and I want to control exactly how the date is displayed. I Figured out how to get the correct portion of the date and time but I want them to be combined into one string that I send to the display. I can send each portion individually but have to specify the location on the display.
I want it to display
Thu, Oct, 12, 2017
not
Thu , Oct , 12 , 2017
The spacing is a little exaggerated to show what I an talking about.
Stay away from the String class, and especially stay away from using the + to put Strings together. It can shoot your heap memory full of holes and Arduino doesn't have any way to clean that up. Plus, lots of libraries are going to use the much safer char arrays and suddenly that String crutch gets hard to use.
You could use sprintf:
char buf[22]; // check this is big enough, I didn't count.
sprintf(buf, "%s, %s, %02d, %04d", rtc.getDOWStr(FORMAT_SHORT), rtc.getMonthStr(FORMAT_SHORT), t.date, t.year);
But the easier method may be just to print the different pieces to the screen separately instead of trying to get it all done in one line.
The '+' operator only works for concatenation on String objects. For character arrays, character pointers, and string constants you would typically use a C library function like strcat(). BE WARNED: It is YOUR responsibility to make sure that your buffer is large enough to hold the combined strings.
Delta_G:
Thank you... This work perfectly.
I am not a c or c++ coder. I have always worked with TCL, and VBA,
This is all very new to me. I am really having difficulty getting the concepts down for some reason. Not sure why. I guess it will click eventually. I am sure part of it is time. I use it as a hobby so I don't get to use it very often.
What are the %s, %s, %02d, %04d for? I read the sprintf and the rest makes sense.
%s means string
%02d means 2 digits
%04d means 4 digits
I this how sprintf sets up the formatting?
Google printf, you're more likely to find a good list of formatters that way.
%s means string Yes, lower case s string, not String class. This is a null terminated char array
%02d means 2 digits Not just 2 digits, the 0 there means to pad with 0's if not long enough
%04d means 4 digits Same here, 4 digits 0 padded.
With a little study, you will find sprintf() a much easier and much more flexible method to get exactly the output format you want, than mucking around with String operators.
In any case, Strings will eventually cause your Arduino to malfunction.
sprintf() is an extremely flexible and powerful function. However, rarely does one program use anything but a small fraction of that power. In the program below:
the versions that uses sprintf() consumes 3348 bytes of flash and 206 bytes of SRAM. The alternative using the simple str*() functions uses 2084 bytes of flash and 190 bytes of SRAM. If you ever find yourself operating at the margins of memory, dropping back to less powerful functions might save the day.
Where'd I get the extra 2 bytes of SRAM from? I expected 190 like the str*() functions version you posted. I figured all I was getting back was the format string. Am I miscounting something? I would say it is temp getting optimized out, but that should be 5 bytes.
econjack:
I don't know. I'm using 1.8.4 of the compiler. Try compiling it and see if your numbers are different.
Don't have one I can use right now (work computer, can't install). I'll take your word for it, I know you know what you're doing. I'm assuming your number is right and my thinking is wrong. I just want to know where I'm counting wrong. Nothing makes me crazier than knowing I got the answer wrong but not knowing why.
