Hi all,
I am trying to create a RS-485 Bussystem in which a master collects sensor data from several slaves. I want the master to ask let's say five slaves in a row for the measured distance data from the hc-sr04 ultrasonic sensor. This distance should be printed out on the serial monitor. The problem I'm facing is that I cannot get the serial conversation between the arduinos get started. I used an Elegoo MEGA2560 R3 as master, an Arduino nano as slave, the hc-sr04 ultrasonic sensor and two RS-485 modules to connect the two controllers.
The connections on the MEGA2560 are the following:
RX0 is connected to R0 of the first RS-485 module,
TX0 is connected to D1 of the first RS-485 module
and PWM PIN 2 is connected to DE and RE.
On the output side of the RS-485 module B and A are plugged into the + and - of my breadboard where the next RS-485 module B and A inputs are also connected to.
R0 PIN goes to Arduino nano (which is the slave) TX1
D1 PIN goes to Arduino nano RX1
RE and DE PINS go to Arduino nano D2.
The trigger PIN of the HC-SR04 is connected with D11 on the nano,
the echo PIN of the HC-SR04 to the D12 on the nano.
I attached the master and slave code and three pictures of my setup to this blog. The codes are partlyderived from Comunicación RS485 con Arduino.
I would greatly appreciate any help!
Best regards,
ambropete
MasterCode:
const int EnTxPin = 2; // HIGH:TX y LOW:RX
Serial.setTimeout(100); //establecemos un tiempo de espera de 100ms
// inicializamos los pines
pinMode(EnTxPin, OUTPUT);
digitalWrite(EnTxPin, HIGH); //RS485 como Transmisor
//---solicitamos una lectura del sensor----------
Serial.print("I"); //inicio de trama
Serial.print("101");//direccion del esclavo
Serial.print("L"); //L para indicarle que vamos a Leer el sensor
Serial.print("F"); //fin de trama
Serial.flush(); //Esperamos hasta que se envíen los datos
//----Leemos la respuesta del Esclavo-----
digitalWrite(EnTxPin, LOW); //RS485 como receptor
if(Serial.find("i"))
int esclavo=Serial.parseInt(); //recibimos la direccion del esclavo
int Distanz=Serial.parseInt(); //recibimos el dato
if(Serial.read()=='f'&&esclavo==101) //si fin de trama y direccion son los correctos
Serial.print("Distanz=");
Serial.print(Distanz);
Serial.println("cm");
//----------fin de la respuesta----------
SlaveCode:
#define trigPIN 11
#define echoPIN 12
const int mydireccion =101; //Direccion del esclavo
pinMode(trigPIN,OUTPUT);
pinMode(echoPIN, INPUT);
if(Serial.available())
Serial.print("Hastalavista");
if(Serial.read()=='I') //Si recibimos el inicio de trama
int direccion=Serial.parseInt(); //recibimos la direccion
if(direccion==mydireccion) //Si direccion es la nuestra
char funcion=Serial.read(); //leemos el carácter de función
//---Si el carácter de función es L entonces el maestro está solicitando una lectura del sensor---
if(funcion=='L')
int duration, distance;
digitalWrite(trigPIN, LOW);
delayMicroseconds(2);
digitalWrite(trigPIN, HIGH);
delayMicroseconds(10);
duration=pulseIn(echoPIN, HIGH);
distance=(duration/2)*0.034;
if(Serial.read()=='F') //Si el fin de trama es el correcto
int lectura = distance; //realizamos la lectura del sensor
digitalWrite(EnTxPin, HIGH); //rs485 como transmisor
Serial.print("i"); //inicio de trama
Serial.print(mydireccion); //direccion
Serial.print(",");
Serial.print(lectura); //valor del sensor
Serial.print("f"); //fin de trama
delay(10);
