What kind of motor driver to use for my Chem E car project
Firstly I would like to apologize for level of noobishness displayed in this question.
I am a HND chemical Engineering student in my final year with no background in science whatsoever, I am a commerce graduate who works part of a Hazmat team for Civil defense. I started pursing the course to better improve my understanding of the work I do and I have managed so far withpout the basics. Now for the final semester I am required to prepare a project. I feel I was somewhat forced into taking Chem e Car for the university. Another aspect being this si supposed to be a group project but none of my classmates made it past the first year so I have been the only one in class for the last 1 year.
A brief description of y project:
My project is adapted from: https://scholarcommons.sc.edu/cgi/viewcontent.cgi?article=1006&context=senior_theses
I am preparing a Chem e Car that is powered by thermo electric generators. I am going to have a hot sink and a cold sink with 6-8 thermoelectric generators placed in between them. This should produce the power to run the car. Now as we are not allowed to use gears my detention mechanism is going to be Iodine clock reaction. Potassium iodide is injected into a container containing Hydrogen sufluide which is initially clear, after a few seconds of injection the mixture will go from clear to blue black. Here I am going to use an LDR to detect the color change and have the car come to a stop upon the color change. I understand the chemicals aspects of the project but I have no idea on the electrical aspects of the project. I had purchased an audrino to control the car. Later someone informed me that I need to have a motor driver as well. Turns out there a lot of specifications of motor drivers and I couldn’t pinpoint which one to buy due to the lack of information on where to start. So if someone could guide me on which motor driver to buy I would really appreciate it.
Along with the audrino I have picked up Darlington transistor, led and LDR’s. Other than the Motor driver would I need to pick up anything else. As my course is for a limited duration I wanted to purchase the relevant materials required for the project so that I can get on ahead to research design and construction of the car.
Sorry but you are getting that the wrong way round. You can't buy all the components you need and THEN start designing something. Until you have a design fairly well worked out you have no way to know what components you will need.
So initially, what adaptations are you making to the design in that paper you linked to? From what you've said so far it sounds like you are simply intending to build their design.
A few questions that need answering -
Why do you think you are not allowed to use gears? You will have a lot of trouble finding ungeared motor(s) that will work.
How much power will you get from your thermo electric generators? What voltage/current?
What size is the car? How much will it weigh ready to run?
But fortunately if the car only needs to go forwards you will not need a motor driver. So that's one worry out of the way. But you should replace the Darlington with a MOSFET, which will be more efficient.
BTW what's a "detention mechanism"?
Steve
That does not say a lot for the course then.
As @slipstick said what on earth is a "detention mechanism"?
Also what is the restriction on gears as the paper you referenced states
However, this speed is also dependent on load and gear ratio. Out of these
parameters, gear ratio is the most significant because it helps to balance
the speed and torque for
our car (8).
At last we can categorically state that this isn't an xy problem.
To find an appropriate motor driver, you first need to know what type of motor you're going to use, and your power supply.
The type of motor depends on the power supply - I guess it's a DC supply so that pretty much narrows it down to brushed or brushless. You'll also need to find out the available current and voltage and with it the total power you have for your motor.
OK so now you have chosen your motor(s). Now it is time to figure out how to control them. Select an appropriate driver based on the voltage and current to be switched, and the type of motor you have. Brushed and brushless are quite different in that respect. Brushed is easiest, a MOSFET transistor will do.
While an Iodine clock is a neat trick, I'm not sure what the point of it is - You can control the desired runtime by use of millis directly in the code. The project you're emulating seems to have no real reason either other than 'because we could'.
slipstick:
Steve
I'm preparing the exact same project according to the paper. The paper states restriction on gear but my university does not require me to comply with that aspect. Just that they want me to produce a car that dosen't run on battery and is powered by a chemical reaction. I purchased a HR16 4WD car chassis that comeswith 4 motors. I think they have built in gears( can't really figure that out)
I will be fabricating the reaction containers today after that only will i be able to determine the power output form the thermometric generators. The size of the car smaller than a shoe box about 20*15cm. The weight of the car is yet to be determined. Once the aluminium containers are fabricated and the required reactants are placed I should be able to determine the weight when the car is ready to run.
Yes the car only needs to run forward, So I will consider taking a MOFSET.
Detention mechanism is the stopping mechanism of the car. Here I am required to use an iodine clock reaction as detention mechanism(to stop the car). Initially i was supposed to use photo resistor but then i was advised to use LDR to detect the color change and use the change in resistance to send signal to stop the car.
ardly:
Level 5 Pearson BTEC Higher National Diploma in Chemical Engineering
Gear restriction does not necessarily need to be applied and neither am I aware of how to implement it
GrooveFlotilla:
hahaha, typo x.x *this
wvmarle:
How to identify if the motor has brushes, the car chassis kit comes with 4 motors for each wheel.
wildbill:
Since it is a chemical engineering project they want most aspects of the project to be a chemical reaction. I had initially suggested Formulation of perfume from plants but they rejected it saying its too simple >.> Now i'm stuck with this and there is not enough help available in this small island.
Mond3:
http://www.haitronic.cn/index.php?route=product/product&product_id=256
.... Initially i was supposed to use photo resistor but then i was advised to use LDR to detect the color change and use the change in resistance to send signal to stop the car.
....Now i'm stuck with this and there is not enough help available in this small island.
Have you got the chassis kit already as if it is coming from China it may take some time to arrive?
The link does not provide much information. It looks like each motor drives a geared axle that probably has a wheel on one side and a "velocimetry code disk" on the other. It looks like it takes 4 1.5V batteries wired in series, so it is using 6V. Are your generators going to produce 6V?
You also need to consider the current. Once you have the kit it may have more information or you may be able to Google it from part numbers etc.
To me a photo resistor and a Light Dependent Resistor (LDR) are the same thing - maybe somebody else knows different.
You big challenge is probably going to be getting the electrical/mechanical aspects of this right so that enough power is generated to drive the car.
What is the role of the Arduino, could everything not be done by electronics?
What small island are you on?
Mond3:
In other words: they're looking for you to build a DIY battery. That's at least what you seem to describe.
Fair chance - such motors easily do a couple thousand RPM. Too fast for most direct drives.
Short from taking it apart: ask the manufacturer.
Oh, GrooveFlotilla referred to this. I have to agree that it's good to know we're not having yet another xy problem on our hands.
Mond3:
The motors are geared. And if they only have 2 wires to connect them they are almost certainly brushed. Brushless motors almost always have 3 wires.
Steve
My BLDC water pumps and BLDC computer fans all have just two wires.
So, you are not contributing anything new. Hmmm.
wvmarle:
So I was correct, almost all brushless motors have three wires. Then there are components containing brushless motors plus controllers which have only two.
So just for completeness do you have any brushed motors with three wires?
Steve
No. All that I have are two-wire motors. Control is of course limited to simple on/off.
ardly:
I purchased the kit from a local shop here. Literally the only shop that sells this here. Only the model number and the picture in the link is displayed. No manual no instructions. So I dont know how much power is required to run it and I dont know yet how much power the thermo electric generators are going to produce. I need to fabricate the containers and sitck the thermo electric generators in betwen and test the output this week but i'm still waiting for "approval" from the HOD to use the workshop. I would have to wait till Sunday to do this. Oh and I have never been to a workshop before.
Tried googling "HR16 4wd" but other than the link nothing useful comes up.
Honestly, I have heard of Raspberry Pi but not of Audrino. It is listed in the thesis they want me build, that is the first time I heard of Audrino. The guys who did the thesis had a team, I am one the only survivor of this course. I dont suppose the task i want can be done without an Audrino or a Raspberry Pi. Would have been better. I need to apply the chemical aspect, the isntrumentation can change.
I am from the Kingdom of Bahrain. Tis a small island.
wvmarle:
It never crossed my mind to ask the manufacturer, I will try that now. Thanks
slipstick:
Steve
The motors have 2 wires. Do I need all 4 motors to run the car?
PaulS:
Forget about contributing. If I can get this car running I would consider it a miracle. Might I remind you I am a commerce graduate. I still don't understand how only I passed through to the second year.
Mond3:
Or the shop that sold you the stuff, of course.
In your case you may be better off ordering stuff off the Internet, then at least you can order things you have technical documentation of (make sure you have that before you press the Buy Now button).
Thanks The motors have 2 wires. Do I need all 4 motors to run the car?
I'd say so. The wheels won't run smoothly by themselves, with those motors attached.
I think you have put the cart before the horse.
E.g. my friends said they would give me a horse, so i ran out and bought a cart to be towed by a horse, then my friends turned up with a minature pony that fitted IN the cart.
Not knowing the voltage and current you will be able to provide means you are making some bad decisions based on assumptions with no basis in reality.
Break the project down.
First assemble the power sourse and do some tests to find out what you have.
  1. How much does it weigh?
  2. How big is it.
  3. What Volts can it supply at What Amps?
  4. How long will your supply last and how long do you need it to last.
You mentioned using thermoelectric generators and making up two aluminum containers to hold your hot and cold water.
Do you realise that the aluminum will radiate heat on all 5 sides not just the side you attach the generators to?
Maby you could use two insulated containers with one wall replaces by aluminum sheet and sealed around the edge with silicone, giving you a surface for the generators.
Do some tests on your carrage to see how much current (Amps) it takes to drive it?
This is the start, you will have facts to let people know so they can help you
I.e. go back to the questions I asked you way back in post #1 and find a few more answers. Without them you have no idea if anything will work. E.g. if your generator can't produce enough power to run even one motor it doesn't matter whether the chassis needs all four motors or not you still won't be going anywhere.
Steve
wvmarle:
Still awaiting reply from the manufacturer. The shop guys asked me to check online.
Daz1712:
  2. How big is it.
I should have the above information by Monday hopefully. Regarding the heat radiation, I was considering providing thermal insulation around the containers. to prevent heat dissipating outside the containers.
slipstick:
Steve
Will do. I really appreciate everyone's help. Honestly I was lost as to where to start and you guys really help me get into the right direction.
I think your next job is to build and measure the thermoelectric generator.
Satellite ones use Pu239 at about 1000K as the source, and radiate waste heat into space at a very low temperature.
I don't think you'll get much from hot and cold water.
Allan
