Hi everyone,
I got a Arduino starter pack as a birthday present yesterday, so please excuse my noobness!
It's some Freeduino that should be equivalent to Arduino Duemilanove with a ATmega168.
My first surprise was when I plugged it into my USB hub and not only did the green power LED light up, but the LED of Port 13 started to blink constantly. Is a brand new board supposed to do that? (From reading the Troubleshooting stuff, I think it is telling me that the boot loader is OK, right?)
Anyway, I tried to upload a first sketch, and the RX LED is blinking shortly, but the TX stays dark. A little bit later (I suppose after some timeout) the Arduino IDE reports this (under OSX):
Binary sketch size: 1018 bytes (of a 14336 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P/dev/tty.usbserial-FTUHMFDZ -b19200 -D -Uflash:w:/var/folders/Ua/UajAKRV7Gf0CH0CwdrTzSk+++TI/-Tmp-/build5958980684931737838.tmp/Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/holger/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbserial-FTUHMFDZ
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: Send: Q [51] [20]
I tried this on the same machine under Win7 as well, with same/similar results.
Using a different USB cable didn't work either.
Tools/Serial Port is working, I can send something and the RX LED blinks shortly. (Am I supposed to get something back? The TX LED is staying dark here as well.)
I tried to change the Baud rate to 9600, but somehow I didn't manage to. (Adding "serial.download_rate=9600" to preferences.txt didn't do it.)
Any more ideas/hints? Ot is the board broken? Should I return it?
Many thanks in advance!
Holger
