Hi, I've been working on doing a line follower robot, that requires me to select which way to go (I use button to select which way). While I was in the final phase of my project, I ran into a problem. I have to use 3 buttons (2 for selecting, 1 for like the enter button). But, when I press the "enter button", the ultrasonic only respond once. I need it to always checking the distance to avoid obstacles.
I use this code to test the it
#define F_trigPin 50
#define F_echoPin 48
int inPin1 = 41;
int inPin2 = 39;
int inPin3 = 35;
int reading;
int reading2;
int reading3;
int previous = HIGH;
int previous2 = HIGH;
int previous3 = HIGH;
int state = LOW;
int state2 = LOW;
long time = 0;
long debounce = 200;
pinMode(F_trigPin, OUTPUT);
pinMode(F_echoPin, INPUT);
pinMode(inPin1, INPUT);
pinMode(inPin2, INPUT);
pinMode(inPin3, INPUT);
reading = digitalRead(inPin1);
reading2 = digitalRead(inPin2);
reading3 = digitalRead(inPin3);
long F_dur, F_cm;
F_trigger_ready();
F_dur = pulseIn(F_echoPin, HIGH);
F_cm = (F_dur/2)/29.1;
if (reading == HIGH && previous == LOW && millis() - time > debounce)
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
if (reading2 == HIGH && previous2 == LOW && millis() - time > debounce)
if (state2 == HIGH)
state2 = LOW;
state2 = HIGH;
time = millis();
if (reading3 == HIGH && previous3 == LOW && millis() - time > debounce)
Serial.print(F_cm);
Serial.println("cm");
if (F_cm < 20)
Serial.println("Detected");
time = millis();
previous = reading;
previous2 = reading2;
previous3 = reading3;
void F_trigger_ready()
digitalWrite(F_trigPin, LOW);
delayMicroseconds(5);
digitalWrite(F_trigPin, HIGH);
delayMicroseconds(10);
inPin1 = first way
inPin2 = second way
inPin3 = enter button
I'm using this button
