Boite musicale
Je viens de tester ça :
 * Code de démonstration d'utilisation d'un module MP3 KT403A avec une carte Arduino.
/* Constantes pour la communication avec le module KT403A */
const byte COMMAND_BYTE_START = 0x7E;
const byte COMMAND_BYTE_VERSION = 0xFF;
const byte COMMAND_BYTE_STOP = 0xEF;
/* Constantes pour la commande setEqualizer() */
const byte EQUALIZER_NORMAL = 0x00;
const byte EQUALIZER_POP = 0x01;
const byte EQUALIZER_ROCK = 0x02;
const byte EQUALIZER_JAZZ = 0x03;
const byte EQUALIZER_CLASSIC = 0x04;
const byte EQUALIZER_BASS = 0x05;
/* Constantes pour la commande selectSourceDevice() */
const byte DEVICE_UDISK = 0x01;
const byte DEVICE_SDCARD = 0x02;
const byte DEVICE_AUX = 0x03; // Not used
const byte DEVICE_PC = 0x04; // Debug only
const byte DEVICE_FLASH = 0x05;
const byte DEVICE_SLEEP = 0x06;
/** Play the next song (all folders) WARNING: files are ordered by creation date! */
void playNextSong() {
  send_kt_command(0x01, 0, 0, 10);
/** Play the previous song (all folders) WARNING: files are ordered by creation date! */
void playPreviousSong() {
  send_kt_command(0x02, 0, 0, 10);
/** Play the given track number (0 ~ 2999) (all folders) WARNING: files are ordered by creation date! */
void playTrack(uint16_t track_number) {
  send_kt_command(0x03, highByte(track_number), lowByte(track_number), 10);
/** Increase the volume */
void volumeUp() {
  send_kt_command(0x04, 0, 0, 10);
/** Decrease the volume */
void volumeDown() {
  send_kt_command(0x05, 0, 0, 10);
/** Set the volume to the given level (0 ~ 30) */
void setVolume(byte volume) {
  if (volume > 30) volume = 30;
  send_kt_command(0x06, 0, volume, 10);
/** Set the equalizer to the given audio mode */
void setEqualizer(byte mode) {
  send_kt_command(0x07, 0, mode, 20);
/** Repeat a single track (0 ~ 2999) (all folders) WARNING: files are ordered by creation date! */
void repeatSingleTrack(uint16_t track_number) {
  send_kt_command(0x08, highByte(track_number), lowByte(track_number), 10);
/** Select the source device for playing */
void selectSourceDevice(byte device) {
  send_kt_command(0x09, 0, device, 200);
/** Enter standby / low power mode */
void enterStandbyMode() {
  send_kt_command(0x0A, 0, 0, 20);
/** Exit standby / low power mode */
void exitStandbyMode() {
  send_kt_command(0x0B, 0, 0, 20);
/** Reset the MP3 module */
void resetPlayer() {
  send_kt_command(0x0C, 0, 0, 100);
/** Play/resume the music */
void playResumeMusic() {
  send_kt_command(0x0D, 0, 0, 20);
/** Pause the music */
void pauseMusic() {
  send_kt_command(0x0E, 0, 0, 20);
/** Select the source folder and track for playing */
void selectSourceFolderAndTrack(byte folder_number, byte track_number) {
  send_kt_command(0x0F, folder_number, track_number, 10);
// 0x10 "Volume adjust set" - NOT SUPPORTED
/** Enable or disable looping of all music files */
void loopAllMusic(byte enabled) {
  send_kt_command(0x11, 0, !!enabled, 10);
/** Select the source track from the "MP3" (case insensitive) folder */
void selectSourceTrackInMp3Directory(uint16_t track_number) {
  // Assert 0 ~ 9999
  send_kt_command(0x12, highByte(track_number), lowByte(track_number), 10);
/** Pause the current track and insert an advertisement song from the "ADVERT" (case insensitive) folder */
void insertSongFromAdvertDirectory(uint16_t track_number) {
  // Assert 0 ~ 9999
  send_kt_command(0x13, highByte(track_number), lowByte(track_number), 10);
/** Play the given song in the given directory (big directory version) */
void selectSourceBigFolderAndTrack(byte folder, uint16_t track_number) {
  // Assert folder 0 ~ 15, track number 0 ~ 9999
  // 0b1100 011111001111 = 4bits folder, 12 bits track number
  send_kt_command(0x14, (folder << 4) | highByte(track_number) & 0x0f, lowByte(track_number), 10);
/** Stop playing the inserted advertisement song and resume playing the user track */
void stopInsertedSongAndResumePlaying() {
  send_kt_command(0x15, 0, 0, 20);
/** Stop the music */
void stopMusic() {
  send_kt_command(0x16, 0, 0, 20);
/** Loop all music in the given folder */
void loopFolder(byte folder_number) {
  send_kt_command(0x17, 0, folder_number, 10);
/** Random playing */
void shufflePlay() {
  send_kt_command(0x18, 0, 0, 20);
/** single repeat the currently playing track track */
void repeatCurrentTrack(byte enabled) {
  send_kt_command(0x19, 0, !enabled, 10);
/** Mute sound output **/
void muteSound(byte enabled) {
  send_kt_command(0x1A, 0, !!enabled, 10);
/** Fonction de bas niveau pour envoyer une commande au module KT403A */
void send_kt_command(byte command, byte data_h, byte data_l, unsigned long cmd_delay) {
  Serial.write(COMMAND_BYTE_START);
  Serial.write(COMMAND_BYTE_VERSION);
  Serial.write((byte) 0x06);
  Serial.write(command);
  Serial.write((byte) 0x00);
  Serial.write(data_h);
  Serial.write(data_l);
  Serial.write(COMMAND_BYTE_STOP);
  // 16-bits checksum is optionnal
  delay(cmd_delay);
/* Fonction setup() */
  /* Initialise le port série */
  /* Initialise le module KT403A */
  resetPlayer();
  selectSourceDevice(DEVICE_SDCARD);
  setVolume(15);
  /* Lit le premier fichier sur la carte SD */
  playTrack(1);
/** Fonction loop() */
Mais il ne veut pas me lire playTrack(1); dans le setup..
Il joue la piste 1 lorsque je met playTrack(1); dans la boucle mais la redémarre en permanence du coup j'ai mis un delay(8000) mais la encore ça ne fonctionne pas bien.. il commence par 8s de silence avant d'envoyer le premier morceau (alors que les 8s viennent après normalement...)
playTrack(1);
delay (8000);
Bref si qu'elqu'un à une solution.. merci :slight_smile:
