J'ai déjà réalisé le code sauf que mes messages (mes println) se superposent sur l'écran et mes boutons ne font pas changer mes pages.
//#define DEBUG
#include // Core graphics library
#include // Hardware-specific library
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Couleurs d'écriture et de fond possible
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define initial 0
#define client 1
#define page11 2
#define page12 3
#define page13 4
#define page14 5
#define page21 6
#define page22 7
#define page23 8
#define page24 9
#define technicien 10
#define page31 11
#define page32 12
#define page33 13
#define page34 14
#define page41 15
#define page42 16
#define page43 17
#define page44 18
const int boutonp = 35 ;
const int boutonm = 37 ;
const int boutonok = 39 ;
int etat=0;
unsigned long envoiMessage(char*texte);
#define DEBUG 1
void setup(void) {
#ifdef DEBUG
Serial.println(F("TFT LCD test"));
Serial.print("TFT size is ");
Serial.print(tft.width());
Serial.print("x");
Serial.println(tft.height());
#endif // DEBUG
tft.reset();
pinMode(boutonp, INPUT);
pinMode(boutonm, INPUT);
pinMode(boutonok, INPUT);
#ifdef DEBUG
uint16_t identifier = tft.readID();
switch (identifier)
case 0x9325: Serial.println(F("Found ILI9325 LCD driver")); break;
case 0x9328: Serial.println(F("Found ILI9328 LCD driver")); break;
case 0x7575: Serial.println(F("Found HX8347G LCD driver")); break;
case 0x9341: Serial.println(F("Found ILI9341 LCD driver")); break;
case 0x8357: Serial.println(F("Found HX8357D LCD driver")); break;
default : Serial.print(F("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.print(F("I try use ILI9341 LCD driver "));
Serial.println(F("If using the Adafruit 2.8" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));
#endif // DEBUG
identifier = 0x9341;
} // fin switch
tft.begin(identifier);
tft.setRotation(3);
tft.setTextColor(WHITE);
tft.setTextSize(3);
tft.fillScreen(BLACK);
#ifdef DEBUG
Serial.print(F("Fin Setup "));
#endif // DEBUG
}//fin setup
void loop(void)
switch(etat)
case initial:
tft.println("Initial");
if (boutonp) etat=client;
if (boutonm) etat=technicien;
case client:
tft.println("Client");
if (boutonp) etat=page11;
if (boutonm) etat=page21;
if (boutonok) etat=initial;
case technicien:
tft.println("technicien");
if (boutonp) etat=page31;
if (boutonm) etat=page41;
case page11:
tft.println("11");
if (boutonp) etat=page12;
if (boutonm) etat=client;
case page12:
tft.println("12");
if (boutonp) etat=page13;
if (boutonm) etat=page11;
case page13:
tft.println("13");
if (boutonp) etat=page14;
if (boutonm) etat=page12;
case page14:
tft.println("14");
if (boutonp) etat=initial;
if (boutonm) etat=page13;
case page21:
tft.println("21");
if (boutonp) etat=page22;
case page22:
tft.println("22");
if (boutonp) etat=page23;
case page23:
tft.println("23");
if (boutonp) etat=page24;
if (boutonm) etat=page22;
case page24:
tft.println("24");
if (boutonm) etat=page23;
case page31:
tft.println("31");
if (boutonp) etat=page32;
case page32:
tft.println("32");
if (boutonp) etat=page33;
if (boutonm) etat=page31;
case page33:
tft.println("33");
if (boutonp) etat=page34;
if (boutonm) etat=page32;
case page34:
tft.println("34");
if (boutonm) etat=page33;
case page41:
tft.println("41");
if (boutonp) etat=page42;
case page42:
tft.println("42");
if (boutonp) etat=page43;
case page43:
tft.println("43");
if (boutonp) etat=page44;
if (boutonm) etat=page42;
case page44:
tft.println("44");
if (boutonm) etat=page43;
default:
tft.println ("Erreur");
tft.setCursor(0, 0);
}//fin loop
unsigned long start = micros();
tft.println(texte);
return micros() - start;
}//fin envoimessage
Si vous avez des solutions à m'apporter ou des questions plus précise ce serait sympa.
Merci A Bientôt.
Screampy57
