I am developing standalone special-purpose thermostat unit with ATMega328p-pu, programmed by pulling the chip out from socket into arduino, so I can't really use serial debugging etc...
Can you please provide a schematic and photograph of your board and setup with the i2c adaptor and lcd?
I believe that the sketch freezing at lcd.begin() with no rblink or gblink after the call is likely to indicate a problem on the i2c bus.
How did you determine the address of the i2c backpack?
had to sniff the address (by modifying the SPI_CHECK, i was able to identify the DEC adress by reading number of LED blinks...), it was 0x3F instead of standard 0x20/0x27
SPI_CHECK makes no sense for an i2c device.
You should be using this program modified to show blinks, and with the chip programmed to run it within the actual circuit.
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
Serial.begin (115200);
// Leonardo: wait for serial port to connect
while (!Serial)
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 8; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
void loop() {}
