You can’t run this stuff off a small 9v battery - it can’t supply the current .
Do you have a SERVO, or servo MOTOR ?
Big difference... one needs the servo library or similar, the other uses an h-bridge or driver to provide the control voltage.
Servos have all the goods in a single box, usually for RC hobby applications.
Servo motors are usually seen in larger automation / industrial control projects.
I have servos. Not servo motors. However, they are both called servo motors, but one is RC servo motors, and the other is industrial servo motors
incorrect. a servomotor is a type of (usually) dc motor.
Do you Serial.prints produce the expected results?
No, it does not
spencerkim:
No, it does not
Well, what do you see?
You know, the more detail you offer, the quicker the debug process will be.
Also:
myservo.attach(2); //attach servo to pin 9
Why does your comment say pin 9 but your call to attach references pin 2?
The Servo library only supports pins 9 or 10.
Edit: N/M, misread library reference...
Where did you get that information?
AnalogWrite on pins 9 and 10 are disabled by the Servo library.
groundFungus:
Where did you get that information?AnalogWrite on pins 9 and 10 are disabled by the Servo library.
Apologies, my mistake: I read this:
but only just noticed that applied to "...Arduino 0016 and earlier...".
I got that information from my friend. I see the light coming on the water sensor and the servo motor not turning on. Where am I suppose to connect the servo motor?
Well, that depends on whether it’s an RC servo or a servo motor,
Please post a link to the product or datasheet
I suggest that you split
setTheServo(readTheSensors());
so that you can print the value returned by readTheSensors() to see whether it matches your expectations
What do you see when you print currentSensorVal ?
You might want to supply a diagram of your wiring. There is not enough current available on the 5V pin on the arduino to power a servo and I guess that is your problem.
The diagram fails to illustrate if the power supply is a 9V battery wired directly to the breadboard?
The 9V power supply is connected to the Arduino Uno board.
Is the servo powered by the Uno 5V (see reply #21)? Or is the servo powered by 9V? Is the servo rated for 9V, if so?
