Hi friends, it's me again Mekaci that I came with lot's of questions to ask and bother you again, but I really need your friends' help once again. I hope that you help me about this topic too.
I finished most of parts in coding and mechanical components for my wireless control robotic tank project and I used Aluminum components in my project and after including the batteries later on etc too, it became heavy ( 35 kg ). I really need you fellow friends' advice to do everything correctly in my project.
The main concept that I want is this: " I don't want my tank's speed so slow but I want my motors to handle the tank's movement smoothly on the ground or while climbing the 45 degree slope on the bulges that when it stops at the middle of the bulge it will not go down ".
#So, my main question is this:
1)What kind of DC motors and battery ( volt and amper ) do I need for my 35 kg robotic tank project ?
**I was planned to use 12v 4A li-po battery but if you advice a stronger version please say and I will get it.
**I will use x4 dc motors and I have x2 "2×15A DC Motor Driver"s on me now too(2×15A DC Motor Driver - DFRobot).
#I have other questions are these:
2) Should I connect the all x4 motors to one motor driver ? or,
3) Should I split the x4 motors as x2 - x2 to x2 motor drives ?
Which one is the efficient way ?
**I used these metal wheels and tank plates too: https://ae01.alicdn.com/kf/HTB1E.R7OFXXXXcRXXXXq6xXFXXXu/Mato-Metal-black-Tracks-sprockets-early-with-metal-caps-idler-wheels-with-bearings-for-Heng-Long.jpg. The radios of this wheel is like this: HL Tiger 1 49.82mm
#My last question are these:
**While I was checking the dc motors, I was encoder dc motor version and it seems it requires lot's of pin slots too in arduino for every dc motor and more detailed coding while using them too. Anyway,
4) Should I use encoder dc motor or normal dc motor to control my tank's movement in my project ?
5) What is the advantages and disadvantages of using encoder dc motors ?
6) Is it easy to use and code the encoder x4 dc motors in arduino ? Never used it before.
#I plan to buy dc motors from this website: MOTION - Motors & Accessories - HD Premium Planetary Gear Motors - ServoCity .
7) Thus, from this list which dc motor should I need ( normal dc version or encoder version too )? thank you.
Note:
**I was tried to use this dc motor calculator: https://www.robotshop.com/blog/en/drive-motor-sizing-tool-9698
**However, I was not quite sure so I wanted to talk with you friends and get real advice. I can buy the things you will say for one time. I am a student after all so I really need your help, thank you very much. Take care yourself and have a nice day all.
