#include <Servo.h>
#include <stdio.h>
#include <SPI.h>
#include <Wire.h>
#include <String.h>
feedback - in fractions of (1/x),
higher x --> reach target location at SLOWER speed but LESS oscillation.
lower x --> reach target location at FASTER speed but MORE oscillation.
YPR_max - in degrees,
limits the maximum Yaw-Pitch-Roll angle of the moving platform
servo_mult - constant
converts output angle (in radians) to microsecond pulses e.g.
pi/3 radians * servo_mult = 600uS
-pi/4 radians * servo_mult = -450uS
const float pi = radians(180), theta_s[6] = { pi, pi, pi/3, pi/3, -pi/3, -pi/3},
L1 = 0.666, L2 = 6, z_home = 110.0,
YPR_max = radians(20), servo_min = radians(-60), servo_max = radians(60), feedback = (1/50),
servo_mult = (1800/pi), ADC_mult = (YPR_max/512),
// p = location of servo rotation points in base frame [x/y][1-6]
p[2][6] = {{-52.3993, 50.8007, 90.3895, 39.5875, -38.2649, -90.3679} ,
{74.8623, 74.8623, 6.2712, -80.5588, -80.4696, 5.8204}},
// re = location of attachment points in end effector frame [x/y][1-6]
re[3][6] = {{-12.0000, 12.0000, 70.2820, 58.2820, -58.2820, -70.2820},
{74.2260, 74.2260, -26.7210, -47.5060, -47.5060, -26.7210},
{-21.075, -21.075, -21.075, -21.075, -21.075, -21.075}};
theta_r = angle between attachment points
theta_p = angle between rotation points
theta_s = orientation of the servos
RD = distance to end effector attachment points
PD = distance to servo rotation points
L1 = servo arm length
L2 = connecting arm length
z_home = default z height with servo arms horizontal
servo_min = lower limit for servo arm angle
servo_max = upper limit for servo arm angle
servo_mult = multiplier to convert to milliseconds
pe = location and orientation of end effector frame relative to the base frame [sway, surge, heave, pitch, roll, yaw)
theta_a = angle of the servo arm
servo_pos = value written to each servo
q = position of lower mounting point of connecting link [x,y,x][1-6]
r = position of upper mounting point of connecting link
dl = difference between x,y,z coordinates of q and r
dl2 = distance between q and r
P1 = translation in X direction (sway) S* = Sin(theta_)
P2 = translation in Y direction (surge) C = Cos(theta_*)
P3 = translation in Z direction (heave) e.g. C1 = Cos(theta_1)
General Matrix for Yaw-Pitch-Roll-Sway-Surge-Heave Transformation
| C2C3 S1S2C3 - C1S3 C1S2C3 + S1S3 P1 | | X | | q[0] |
| C2S3 S1S2S3 + C1C3 C1S2S3 - S1C3 P2 | x | Y | = | q[1] |
| -S2 S1C2 C1C2 P3 | | Z | | q[2] |
| 0 0 0 1 | | 1 | | 1 |
where:
X = L1 theta_1 = 0
Y = 0 theta_2 = theta_a
Z = 0 theta_3 = theta_s
const int servo_pin[6] = {2, 3, 4, 5, 1, 6}; //3,6,10 Reversed
const int servo_zero[6] = {1710, 1280, 1700, 1300, 1680, 1300};
//const int servo_pin[] = {9,3, 5, 11, 6, 10},
//servo_zero[6] = {1500, 1500, 1500, 1500, 1500, 1500};
// servo_pin = servo pin assignments,
// servo_zero = zero angles for each servo (horizontal)
// */ is a multiline comment
Servo servo[6];
// Servos 0, 2, 4: reversed (+ = down, - = up)
// Servos 1, 3, 5: normal (+ = up, - = down)
servo[0].attach(3, MIN, MAX);
servo[1].attach(5, MIN, MAX);
servo[2].attach(6, MIN, MAX);
servo[3].attach(9, MIN, MAX);
servo[4].attach(10, MIN, MAX);
servo[5].attach(11, MIN, MAX);
// opens serial port, sets data rate to 9600
for(int i = 0; i < 6; i++);
servo.attach(servo_pin*);
servo.writeMicroseconds(servo_zero);
_}*_
*void loop()
float pe[6] = {0,0,0,radians(0),radians(0),radians(0) }, theta_a[6], servo_pos[6],q[3][6], r[3][6], dl[3][6], dl2[6];
pe[0] = (analogRead(0)-512)/51.2; // 1023/103.2 for Arduino Mega//
pe[1] = (analogRead(1)-512)/51.2;
pe[2] = (analogRead(2)-512)/51.2;
pe[3] = (analogRead(3)-512)*ADC_mult;//(analogRead(3)-1023)*ADC_mult;//
pe[4] = (analogRead(4)-512)*ADC_mult;
pe[5] = (analogRead(5)-512)*ADC_mult;
Serial.println("SERVO");
/* theta_1=0, Y=0, Z=0, P3=0
| C2C3 0 0 P1 | | X | | q[0] | | X(C2C3) + P1 |
| C2S3 0 0 P2 | x | 0 | = | q[1] | = | X(C2S3) + P2 |
| -S2 0 0 0 | | 0 | | q[2] | | X(-S2) |
| 0 0 0 1 | | 1 | | 1 | | 1 |
// theta_a = angle of the servo arm
// theta_s = orientation of the servos
if(i%2 == 0)
q[0][i] = L1cos(-theta_a[i])cos(theta_s[i]) + p[0][i]; //EVEN [0,2,4]
q[1][i] = L1cos(-theta_a[i])sin(theta_s[i]) + p[1][i];
q[2][i] = -L1sin(-theta_a[i]);
q[0][i] = -L1cos(theta_a[i])cos(theta_s[i]) + p[0][i]; //ODD [1,3,5]
q[1][i] = -L1cos(theta_a[i])sin(theta_s[i]) + p[1][i];
q[2][i] = L1sin(theta_a[i]);
// Z = 0 to simplify equation
// r = position of upper mounting point of connecting link
// pe = location and orientation of end effector frame relative to the base frame [sway, surge, heave, pitch, roll, yaw)
// Calculation of Rotational Matrix from basic equation //
r[0][i] = re[0][i] * cos(pe[4]) * cos(pe[5]) + re[1][i] * (sin(pe[3]) * sin(pe[4]) * cos(pe[5]) - cos(pe[3]) * sin(pe[5])) + re[2][i] * ((cos(pe[3]) * sin(pe[4]) * cos(pe[5])) + sin(pe[3]) * sin(pe[5])) + pe[0];
r[1][i] = re[0][i] * cos(pe[4]) * sin(pe[5]) + re[1][i] * (cos(pe[3]) * cos(pe[5]) + sin(pe[3]) * sin(pe[4]) * sin(pe[5])) + re[2][i] * ((cos(pe[3]) * sin(pe[4]) * cos(pe[5])) - sin(pe[3]) * cos(pe[5])) + pe[1];
r[2][i] = -re[0][i] * sin(pe[4]) + re[1][i] * sin(pe[3]) * cos(pe[4]) + re[2][i] * (cos(pe[3]) * cos(pe[4])) + z_home + pe[2];
// dl = difference between x,y,z coordinates of q and r
dl[0][i] = q[0][i] - r[0][i];
dl[1][i] = q[1][i] - r[1][i];
dl[2][i] = q[2][i] - r[2][i];
// dl2 = distance between q and r
// L2 = connecting arm length
dl2[i] = sqrt(dl[0][i]*dl[0][i] + dl[1][i]*dl[1][i] + dl[2][i]*dl[2][i]) - L2;
// feedback in fractions of (1/x),
// higher x --> reach target location at SLOWER speed but LESS oscillation.
// lower x --> reach target location at FASTER speed but MORE oscillation.
theta_a[i] += (dl2[i]*feedback);
Serial.println(dl2);
// theta_a = angle of the servo arm in radians
theta_a[i] = constrain(theta_a[i], servo_min, servo_max);
if(i%2 == 0) servo_pos[i] = servo_zero[i] + theta_a[i]servo_mult; //EVEN - normal
else servo_pos[i] = servo_zero[i] - theta_a[i]servo_mult; //ODD - reversed
// if(i%2 == 1) servo_pos = servo_zero + theta_aservo_mult;
// else servo_pos = servo_zero - theta_aservo_mult;
servo[i].writeMicroseconds(servo_pos[i]);
_```
*_
