Topic: Standalone 328p and watchdog reset (Read 320 times) previous topic - next topic
geologic
Hi
Hi have a standalone 328p running at 8Mhz that i program with arduino as ISP
I set a watchdog interrupt each second, and after 10 seconds it resets the device.
The problem is after reset, it enters a infinite loop.
I already put wdt_disable(); at setup() to give time to start, but didn't solve.
I read about a bug on bootloader, but i'm using a bare 328p, not a board
Below is code i use. Any ideas?
Code: [Select]
void watchdogEnable() {
 wdt_count=0;
 cli();                              // disable interrupts
 MCUSR = 0;                          // reset status register flags
 WDTCSR |= 0b00011000;               // Set WDCE and WDE:
 WDTCSR =  0b01000000 | 0b000110;    // set WDIE, clr WDE, set delay to 1 sec
 sei();      // re-enable interrupts
ISR(WDT_vect) {
 wdt_count++;
 if (wdt_count < MaxHangs) {
wdt_reset(); // start timer again (still in interrupt-only mode)
   MCUSR = 0;                          // reset flags
   WDTCSR |= 0b00011000;               // Put timer in reset-only mode:
   WDTCSR =  0b00001000 | 0b000101;    // clr WDIE, set WDE, reset interval to 1s
   Serial.println("Reseting...");
6v6gt
1. Post all your code.
2. Don't do this in an ISR: Serial.println("Reseting...");
3. Look at https://gammon.com.au/interrupts for some examples.
geologic
Well, according to this post, i have to clear WDRF bit at setup, doing wdt_disable(); is not enough:
https://forum.arduino.cc/index.php?topic=176329.msg1309241#msg1309241
this way it is working:
Code: [Select]
  MCUSR = MCUSR & B11110111;     // with this line it works
  wdt_disable();
