I noticed my post on the Eigen library was for the pc and not the arduino one I wrote for the Due.
I used the library tutorial and got the newest stable release of Eigen to run.
I wold add my ziped library file if I could to make it easier to run Eigen libraries on the DUE in win/linux/mac.
A header and ccp file was needed I named the folder in home/arduino/libraries EIGEN.
The header file was Eigen.h and program file Eigen.cpp
Eigen.h - Library for adding Eigen library code.
Created by Joshua Wojnas, September 15, 2015.
#ifndef Eigen_h
#define Eigen_h
#include "Dense"
#include "LU"
#include "Arduino.h" //statement that gives you access to the standard types and constants of the Arduino
using Eigen::MatrixXd;
using namespace std;
using namespace Eigen;
#endif
Eigen.cpp - Library for adding Eigen library code.
#include "Dense"
#include "LU"
#include "Arduino.h"//give the rest of the code access to the standard Arduino functions
#include "Eigen.h"
Then their was the program I used to test it by randomvibe
//Eigan library test by josheeg example by random vibe and eigen library team.
#include <Eigen.h>
// PRINT MATRIX (float type)
// By: randomvibe
void print_mtxf(const Eigen::MatrixXf& K);
// DECLARE MATRICES
MatrixXf Pp(6, 6); // Produces 6x6 float matrix class
MatrixXf H(6, 6); // Note: without "using namespace Eigen", declaration would be: Eigen::MatrixXf H(6,6);
MatrixXf R(6, 6);
MatrixXf X(6, 6);
MatrixXf K(6, 6);
MatrixXf Z(6, 6);
// INPUT MATRICES (so-called comma-initialize syntax)
Pp << 0.3252, 0.3192, 1.0933, -0.0068, -1.0891, -1.4916,
-0.7549, 0.3129, 1.1093, 1.5326, 0.0326, -0.7423,
1.3703, -0.8649, -0.8637, -0.7697, 0.5525, -1.0616,
-1.7115, -0.0301, 0.0774, 0.3714, 1.1006, 2.3505,
-0.1022, -0.1649, -1.2141, -0.2256, 1.5442, -0.6156,
-0.2414, 0.6277, -1.1135, 1.1174, 0.0859, 0.7481 ;
H << 0.8147, 0.2785, 0.9572, 0.7922, 0.6787, 0.7060,
0.9058, 0.5469, 0.4854, 0.9595, 0.7577, 0.0318,
0.1270, 0.9575, 0.8003, 0.6557, 0.7431, 0.2769,
0.9134, 0.9649, 0.1419, 0.0357, 0.3922, 0.0462,
0.6324, 0.1576, 0.4218, 0.8491, 0.6555, 0.0971,
0.0975, 0.9706, 0.9157, 0.9340, 0.1712, 0.8235;
R << 0.3252, 0.3192, 1.0933, -0.0068, -1.0891, -1.4916,
-0.2414, 0.6277, -1.1135, 1.1174, 0.0859, 0.7481;
// Kalman Gain Example; Matlab form: K = Pp * H' * inv(H * Pp * H' + R)
X = H * Pp * H.transpose() + R;
K = Pp * H.transpose() * X.inverse();
// Print Result
print_mtxf(K); // Print Matrix Result (passed by reference)
// By: randomvibe
void print_mtxf(const Eigen::MatrixXf& X)
int i, j, nrow, ncol;
nrow = X.rows();
ncol = X.cols();
Serial.print("nrow: "); Serial.println(nrow);
Serial.print("ncol: "); Serial.println(ncol);
Serial.println();
for (i=0; i<nrow; i++)
for (j=0; j<ncol; j++)
Serial.print(X(i,j), 6); // print 6 decimal places
Serial.print(", ");
Serial.println();
Serial.println();
