Hi guys,
im so sorry to bother you all but i need to translate this code into registry like PORTD=0b0000000
for example cuz im not really good at it and the code is very simple.
and i have a problem i cant make the LEDs fade in and out i dont know how to do it.
it would be great if anyone could help
#include <IRremote.h>
int receiver_pin = 8;
int first_light_pin = 7;
int second_light_pin = 6;
int third_light_pin = 5;
int fourth_light_pin = 4;
int led_case[] = {0,0,0,0,0};
IRrecv receiver(receiver_pin);
decode_results output;
#define code1 48703
#define code2 58359
#define code3 6375
#define code4 25979
receiver.enableIRIn();
pinMode(first_light_pin, OUTPUT);
pinMode(second_light_pin, OUTPUT);
pinMode(third_light_pin, OUTPUT);
pinMode(fourth_light_pin, OUTPUT);
if (receiver.decode(&output))
unsigned int value = output.value;
switch(value)
case code1:
if(led_case[1] == 1)
digitalWrite(first_light_pin, LOW);
led_case[1] = 0;
digitalWrite(first_light_pin, HIGH);
led_case[1] = 1;
case code2:
if(led_case[2] == 1)
digitalWrite(second_light_pin, LOW);
led_case[2] = 0;
digitalWrite(second_light_pin, HIGH);
led_case[2] = 1;
case code3:
if(led_case[3] == 1)
digitalWrite(third_light_pin, LOW);
led_case[3] = 0;
digitalWrite(third_light_pin, HIGH);
led_case[3] = 1;
case code4:
if(led_case[4] == 1)
digitalWrite(fourth_light_pin, LOW);
led_case[4] = 0;
digitalWrite(fourth_light_pin, HIGH);
led_case[4] = 1;
Serial.println(value);
receiver.resume();
