Hi Keola,
i agree with Riccardo. likely your panel is only able to display that single resolution and is forcing PC to output it. at the moment Vidor does not check EDID (the memory which contains panel info) so it outputs a fixed resolution which by standard shall be supported by every display. apparently this is not the case for your panel... maybe you want to try with a different one?
