Hello,
I received my Arduino Uno. I am using Debian 9 stable and not able to use the arduino soft because of this error :
jre@Debian:~$ sudo arduino
[sudo] Mot de passe de jre :
Exception in thread "main" java.lang.ExceptionInInitializerError
at processing.app.Preferences.save(Preferences.java:735)
at processing.app.Preferences.init(Preferences.java:249)
at processing.app.Base.main(Base.java:117)
Caused by: java.lang.NumberFormatException: For input string: "9-D"
at java.base/jdk.internal.math.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2054)
at java.base/jdk.internal.math.FloatingDecimal.parseFloat(FloatingDecimal.java:122)
at java.base/java.lang.Float.parseFloat(Float.java:455)
at java.base/java.lang.Float.<init>(Float.java:554)
at processing.core.PApplet.<clinit>(Unknown Source)
... 3 more
I already tried to follow some instructions but it doesn't help me:
1 : Looks like the IDE did not get installed properly. Install from the "Download" tab above. Before you do that, be sure to rename any existing "Arduino15" directory: /home/(username)/.arduino15 (a.k.a. ~/.arduino15)
Thank you for your help.
