Wiring problems on a big project
I am working on an Escape Room project and the room i'm currently working on has over 20 arduinos connected to a central system (Arduino Mega connected to PC).
So i pretty much ended with a few dozen cables next to each other: arduino inputs and outputs, audio cables, 220v power. For inputs and outputs i've used cat5 UTP cable and speaker wires. The result is a lot of interference and random input triggers, and i think it's mostly caused by 220v wires to the UTP cables (when i plug or unplug something in the 220v socket it often gives a random input).
I started doing some research on the subject but i'm still not sure what would be the best approach.
-Replacing the standard cat cable with shielded cat - i've only found it in large quantities and it's quite expensive. Would this guarantee to protect it from outside noise?
-Replacing the cat cable with speaker cable (black and red thick cable 2x0.5mm). The ones i have installed seem fine so far but i'm not sure. Is it a better choice than cat cable?
-Reinstalling the 220v cables so it's at a distance of at least 30cm from the input cables.
-Installing diodes at the end of input wires to prevent a reverse signal.
-Installing capacitors or resistors on the input wires.
Any help would be appreciated.
When using the CAT-5 cable, is one wire of each pair a ground wire? If not, then that is part of the problem.
Paul
It isn't, i used a single ground per arduino, not per input. I'll definitely try this.
Are you using only the internal pullups? A stronger pullup like 4k7 or 1k will overpower a lot of interference.
Always try to route power wires in separate conduits or separate shielded bundles. Also consider any 12v devices may have significant inductive spikes that radiate interference.
MorganS:
Yes, only internal pullups.
How should i shield the bundles?
Why not mount your Arduinos close to their respective I/O circuits then use a serial connection between the boards to carry the data between them - simplifying and reducing your wiring.
petronel:
If you buy 4-core shielded cable then use all cores for either power or data, not a mix of both if possible.
Once you've created the bundles, it's too late. While there are some shielding products you can put over a wire bundle, it's not cost-effective.
hammy:
The configuration is like this:
PC <--serial--> Arduino Mega <--I/O--> Arduino Uno's <--I/O--> sensors/buttons/audio outputs/lights/motors
Mounting the Uno's close to the Mega means i'll have the same or even more wires to their respective I/O which is probably worse.
And i don't know about connecting 20 Uno's via serial to a Mega that is already controlled via serial. Could that work?
What @hammy was saying is to mount the UNOs close to the sensors/buttons/etc. Next you can use serial communication (RS232, RS422, RS485 depending on needs, not TTL levels) to communicate from / to Mega.
