Topic: Atmega 2560 (Read 245 times) previous topic - next topic
sanjithkumar
The following values are set in PORTH and DDRH registers of Atmega 2560.
DDRH=0xFF;
PORTH=0xFF;
All the pins of Port H are connected to GND or 0 volts. If the values in PORTH and PINH registers are read, what will be the values?
outsider
#1
Jan 17, 2018, 09:01 pm Last Edit: Jan 17, 2018, 09:02 pm by outsider
DDRH=0xFF;   Makes all PORTH pins OUTPUTs, PORTH=0xFF; makes all PORTH pins HIGH, if you connect a pin to GND it will be a SHORT CIRCUIT, and probably BURN OUT the pin!
GolamMostafa
#2
Jan 19, 2018, 07:05 am Last Edit: Jan 19, 2018, 09:04 am by GolamMostafa
@sanjithkumar -- OP
This post is the pictorial version of Post#1 (hopefully!), and it is shown only for one port-pin (Bit-3 of Port-H). Hope that you will be able to find the answers of your questions from this post and Post#1. We will be glad to hear your answers in your next post in this thread.
Figure-1: Port-H structure with short circuit fault at Pin-15
Can you compute the level (how much) of fault power at Pin-15 of ATmega2650 of Fig-1?
