couka:
Please include your code directly in the post, using [code][/code] tags.
lg, couka
(it looks like code tags don't work on this board, but I know you guys hate clicking external links, so here it is anyway)
as linked in the OP, code:
[code]#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
/* This driver reads raw data from the BNO055
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground
History
2015/MAR/03 - First release (KTOWN)
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055();
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("Orientation Sensor Raw Data Test"); Serial.println("");
/* Initialise the sensor /
if(!bno.begin())
/ There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
/* Display the current temperature */
int8_t temp = bno.getTemp();
Serial.print("Current Temperature: ");
Serial.print(temp);
Serial.println(" C");
Serial.println("");
bno.setExtCrystalUse(true);
Serial.println("Calibration status values: 0=uncalibrated, 3=fully calibrated");
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
// Possible vector values can be:
// - VECTOR_ACCELEROMETER - m/s^2
// - VECTOR_MAGNETOMETER - uT
// - VECTOR_GYROSCOPE - rad/s
// - VECTOR_EULER - degrees
// - VECTOR_LINEARACCEL - m/s^2
// - VECTOR_GRAVITY - m/s^2
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
/* Display the floating point data */
Serial.print("X: ");
Serial.print(euler.x());
Serial.print(" Y: ");
Serial.print(euler.y());
Serial.print(" Z: ");
Serial.print(euler.z());
Serial.print("\t\t");
// Quaternion data
imu::Quaternion quat = bno.getQuat();
Serial.print("qW: ");
Serial.print(quat.w(), 4);
Serial.print(" qX: ");
Serial.print(quat.y(), 4);
Serial.print(" qY: ");
Serial.print(quat.x(), 4);
Serial.print(" qZ: ");
Serial.print(quat.z(), 4);
/* Display calibration status for each sensor. */
uint8_t system, gyro, accel, mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
Serial.print("CALIBRATION: Sys=");
Serial.print(system, DEC);
Serial.print(" Gyro=");
Serial.print(gyro, DEC);
Serial.print(" Accel=");
Serial.print(accel, DEC);
Serial.print(" Mag=");
Serial.println(mag, DEC);
delay(BNO055_SAMPLERATE_DELAY_MS);
}[/code]
raschemmel:
Did you do all this : ?
The most reliable way to resolve this issue is simply open a support ticket on the Adafruit Support forum. It will take a day or two for them to respond but they answer all the tickets. I have used it and they would be more likely to know what the problem is. I suspect it is "operator error" but no doubt you will swear up and down you did everything correctly so I'll let Adafruit address that issue.
Figure 8-ing the sensor is what jams it.
