i am using led strips i purchased off of adafruit they are analog led strips.
i have 3 of these strips connected to a arduino mega but i am just looking to light each strip up a different color one red, one green, one blue. i know this is simple but i cant find code to just light a strip up an individual color. even if you just write the code for one strip to light up a color that should be good enough when i look at the code for led strips with effects like fading in and out it confuses me. thank you to anyone who can help.
hello i am new to electronics and coding and was wondering if anyone can help me with the problem i am having. i am doing a school project where i am programming three led strips to light up but only one will light up at a time and it will be randomly. and then i want to put a touch sensor at each strip so when touched the strip will turn off and a new one will light up. i have code that basically does this....It generates a number 1-100 and numbers 1-33 will turn strip 1 green numbers 34 - 66 will turn strip green and numbers 67-100 will turn strip 3 green. here is the code.
also i used an arduino mega for this project along with some analog rgbw strips i got off of adafruit i will be using a shield for capacitive touch but for right now i need to get the code right with the simple ones.
#define REDPIN 3
#define GREENPIN 4
#define BLUEPIN 2
#define REDPINTWO 8
#define GREENPINTWO 9
#define BLUEPINTWO 7
#define REDPINTHREE 12
#define GREENPINTHREE 13
#define BLUEPINTHREE 11
#define FADESPEED 5
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
pinMode(REDPINTWO, OUTPUT);
pinMode(GREENPINTWO, OUTPUT);
pinMode(BLUEPINTWO, OUTPUT);
pinMode(REDPINTHREE, OUTPUT);
pinMode(GREENPINTHREE, OUTPUT);
pinMode(BLUEPINTHREE, OUTPUT);
int randomNum = random(1,100);
Serial.println(randomNum);
if(randomNum<=33){
digitalWrite(GREENPIN,255);
digitalWrite(GREENPINTHREE,0);
digitalWrite(GREENPINTWO,0);
delay(3000);
else if(randomNum>=34 && randomNum<=66){
digitalWrite(GREENPINTHREE,255);
digitalWrite(GREENPIN,0);
delay(3000);
else {
digitalWrite(GREENPINTWO,255);
delay(3000);
so right now it switches strips by by time and i want to use the touch sensors to change the colors. i dont know what the easiest way of doing this would be when i tried to write code it didnt work what so ever. thank you to anyone who can help i hope my description was detailed enough.
Isn't the whole point of a school project like this to learn how to do it yourself, rather than paying other people to do it for you?
if someone shows me how to do it then i wont need to ask next time i need to do something like this. i dont want to pay someone to do it for me i want someone to explain how to do it so i can learn how to do it. i would post it in the coding section of the forum but whenever i post questions in there they tell me to post it here.
This belongs in "project guidance" rather than "gigs & collaborations" which is for paid jobs.
For your code:
First of all I suggest you to put the pins in arrays, then take a random number 0-2, and light the strip with the number chosen. That makes it a lot easier already, as you can simply use the number chosen as index for the strip to light. Like this:
const byte redLED[3] = {2, 3, 4};
byte strip = random(0, 2);
for (byte i = 0; i++; i < 3) {
digitalWrite(redLED[strip], (strip == i) ? HIGH : LOW);
delay(3000);
Just set your pin numbers and add the other two strips and this does the same as your code.
Line 6 sets the pins of all the three strips, as the other two have to be switched off of course.
Now the tricky bit: the change upon touch.
- build a touch sensor.
- get it to work: upon touch, just print the message "touched" (this will be the hardest part).
- take a new random number upon touch and set the LEDs again (quite trivial).
i recently posted this in the gigs and colaborations section but it was the wrong section to post it in. someone who i am very grateful for sent me this code which basically says pick a random number 1-3 and light one of the strips up green and it cycles randomly. i just need to tell it to wait until the touch sensor is touched to change colors here is the code so far.
const byte greenLED[3] = {4, 8, 12};
const byte touchPin[1] = {9};
pinMode(4, OUTPUT);
pinMode(8, OUTPUT);
pinMode(12, OUTPUT);
pinMode(touchPin, INPUT);
int touchValue = digitalRead(touchPin);
byte strip = random(3);
for
(byte i = 0; i++; i < 3){
digitalWrite(greenLED[strip], (strip == i) ? HIGH : LOW);
i tried putting in a do while but then i cant get the code to compile. if anyone could help i would greatly appreciate it i am new to coding.
wvmarle made the most important suggestion.
Break your code into functions.
Get each piece of the project working by itself - only then plug the pieces of code together.
- Wiring - check that you have that all sorted - including adequate power supply
- Get the LEDs working - so you can control whatever functionality you need,
- Touch sensing - one first, test with serial (no LEDs) - you will eventually have three sensors?
- Random number selection from a touch event.
- Tie the touch+random number to set the LEDs the way you need them
