Topic: EM shutter almost working. Still a few things needed... (Read 729 times) previous topic - next topic
Quoll
My electromagnetic shutter is almost complete, but lacking a few essential things both in programming and hardware.
First of all, when the input causes the interrupt function, the CAMERA output instantly switches to LOW, yet it should be HIGH until it is told to go LOW.
Second, when interrupted, the program needs to go back to the first line of the loop(), it instead locks into finishing the full delay, not allowing any interruptions.
This is the code below...
#include <avr/io.h>
#include <avr/interrupt.h>
#define INTERRUPTPIN PCINT1
#define PCINT_VECTOR PCINT0_vect
#define DATADIRECTIONPIN DDB1
#define PORTPIN PB2
#define READPIN PINB2
#define SHUTTER 0
#define CAMERA 2
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
static volatile byte LEDState;
    cli();
    pinMode(SHUTTER, OUTPUT);
    pinMode(CAMERA, OUTPUT);
    LEDState = 0;
    PCMSK |= (1 << INTERRUPTPIN);
    GIMSK |= (1 << PCIE);
    DDRB &= ~(1 << DATADIRECTIONPIN); //cbi(DDRB, DATADIRECTIONPIN);
    PORTB |= (1<< PORTPIN); //cbi(PORTB, PORTPIN);
    sei();
digitalWrite(CAMERA, HIGH);
delay(5000);
digitalWrite(CAMERA, LOW);
ISR(PCINT_VECTOR)
  byte pinState;
  pinState = (PINB >> READPIN)& 1;
  if (pinState >0)
digitalWrite(SHUTTER, HIGH);
delay(200);
digitalWrite(SHUTTER, LOW);
digitalWrite(CAMERA, LOW);}
Nathan Litjens
Quoll
Another problem is the reaction to an input is unreliable, sometimes responding, and other times not...
Nathan Litjens
vaj4088
Complete code should be shown.
CTRL-T in the Arduino IDE should be used to auto-format the code.
Interrupt Service Routines (ISRs) should execute quickly.  Thus, they should NEVER contain a call to delay(...).
Instead of using delay(...) in the loop function to waste ten seconds of time, a millis() based approach could do the same job and would not need an ISR.
Arduino programmers usually avoid pins 0 and 1 because they are shared with the serial port.
Quoll
Thanks for replying, I really appreciate it
Here is the complete code, modified from a tutorial I found, so it contains some notes.
//Includes
#include <avr/io.h>
#define INTERRUPTPIN PCINT1 //this is PB1 per the schematic
#define PCINT_VECTOR PCINT0_vect  //this step is not necessary
#define DATADIRECTIONPIN DDB1 //Page 64 of data sheet
#define PORTPIN PB2 //Page 64
#define READPIN PINB2 //page 64
#define SHUTTER 0 //PB0
#define CAMERA 2 //PB2
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit)) //OR
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit)) //AND
   Alias for the ISR: "PCINT_VECTOR" (Note: There is only one PCINT ISR.
   PCINT0 in the name for the ISR was confusing to me at first,
   hence the Alias, but it's how the datasheet refers to it)
static volatile byte LEDState; //variable used within ISR must be declared Volatile.
  cli();//disable interrupts during setup
  pinMode(SHUTTER, OUTPUT); //we can use standard arduino style for this as an example
  digitalWrite(SHUTTER, LOW); //set the LED to LOW
  LEDState = 0; //we use 0 for Low state and 1 for High
  PCMSK |= (1 << INTERRUPTPIN); //sbi(PCMSK,INTERRUPTPIN) also works but I think this is more clear // tell pin change mask to listen to pin2 /pb3 //SBI
  GIMSK |= (1 << PCIE);   // enable PCINT interrupt in the general interrupt mask //SBI
  DDRB &= ~(1 << DATADIRECTIONPIN); //cbi(DDRB, DATADIRECTIONPIN);//  set up as input  - pin2 clear bit  - set to zero
  PORTB |= (1 << PORTPIN); //cbi(PORTB, PORTPIN);// disable pull-up. hook up pulldown resistor. - set to zero
  sei(); //last line of setup - enable interrupts after setup
  delay(20000);
  //If you connect a debounced pushbutton to PB2 and to VCC you can tap the button and the LED will come on
  //tap the button again and the LED will turn off.
//this is the interrupt handler
ISR(PCINT_VECTOR)
  //Since the PCINTn triggers on both rising and falling edge let's just looks for rising edge
  //i.e. pin goes to 5v
  byte pinState;
  pinState = (PINB >> READPIN) & 1; //PINB is the register to read the state of the pins
  if (pinState > 0) //look at the pin state on the pin PINB register- returns 1 if high
    delay(30);
So you are saying that if I used the millis() I could do away with ISRs altogether? Would I use an if/else instead?
I do need the loop to be able to be interrupted at any time as quickly as possible, but the other sequence to run through entirely, no matter how short the interruption.
Thanks again so much for replying. This thing has had me going round in circles for days!
Nathan Litjens
Quoll
I have changed the delay() to millis() and I get "too many arguments to function 'long unsigned int millis()'". I don't know what to do about this, I'm brand new to Arduino...
Nathan Litjens
vaj4088
You cannot just replace the word "delay" with the word "millis" and have your program work.  I suggest that you read the documentation for the function millis at https://www.arduino.cc/reference/en/language/functions/time/millis/
and also read Using millis() for timing.  A beginners guide
Almost nothing else can occur during delay ("Almost nothing else" means "Nothing except interrupts").  However, if your loop function will check the input pin, then there can be a response nearly as fast (or perhaps even faster than) as using an ISR, and much easier to debug.  You would, indeed, be using an if/else instead.
Please revise your program after you read both links that I posted above.  Using millis() instead of delay(...) usually means restructuring your program, but your program is small enough that any restructuring should go quickly.
I cannot say how fast this can go (because I do not know all Arduinos and you have not told me what you have or what its clock speed is) but it can go very fast.  Microseconds, even.
This code
costs time on many Arduinos because of the shift operator ">>".  Because you only compare to zero, it would be better to shift the "1" in the other direction and not shift the value from PINB at all.  The compiler should be "smart" enough to calculate this constant once and use it instead of a shift.  If the code is sufficient as it stands, perhaps you do not "...need the loop to be able to be interrupted at any time as quickly as possible...".
For some people, "...as quickly as possible..." is femtoseconds.  For other people, "...as quickly as possible..." means seconds.  What is your requirement?
Quoll
Thanks again,
I'll see if I can make sense of how to restructure it. So does that mean the delay function can still be used in the "else" code? If I understand correctly it will block everything else and finish what it has been told to do.
My response time would hopefully be 1-5 milliseconds at the most, as this is to detect and respond to small, fast insects flying through the focal area of a camera lens.
Using attiny85 with 8mhz internal clock
Thanks, I'll see how I go with restructuring...
Nathan Litjens
Quoll
I've been ripping my hair out trying to figure out how to adapt any of this to make the loop run.
Nathan Litjens
vaj4088
For a response time of one millisecond, using the loop function and avoiding the ISR should work very well.  Perhaps if you sleep on it there will be less hair ripped out?
You can mix delay(...) and millis() but it is usually not a good idea because it confuses some people.  Once you get used to using millis() and keeping track of state, you may wonder why you ever bothered with delay(...).
Figure out your states, such as waiting to be triggered, shutter open, waiting with shutter open, shutter closed, waiting while film advances, etc.  Experts use an enum but you can just assign an integer to each one and keep track of the current state by using an int variable.  Use a switch/case statement to do the right thing for the current state.  Use the loop() function to do the looping that you will need to do.
Use an unsigned long variable to hold the time [millis()] of an interesting event, and use subtraction to determine whether sufficient time has elapsed since the interesting event.
I am tempted to write the code myself but I do not really understand what you are attempting to accomplish.
Quoll
The order of operations is
loop (2 minutes)
1 ensure shutter output is LOW
2 camera output HIGH
3 keep camera output high for 2 minutes
4 camera output to LOW
If it is interrupted at any time in the loop, the following needs to happen and complete without interruptions:
1 Camera should still be HIGH
2 shutter output to HIGH
3 Hold for 100 milliseconds
4 Shutter output to LOW
5 Camera output to LOW
6 Wait 1 second before returning to loop
This should be simple and it frustrates me to no end that I cannot seem to find a way to make it work, all of the examples in tutorials are of little help as they are just for blinking LEDs - I really have no idea how to adapt it. I have been working on this project for days with nothing to show...
Nathan Litjens
Quoll
This is the code still missing the millis(). I am still stuck on how to put this function in.
const int CAMERA = 0;
const int SHUTTER = 1;
const int IN = 4;
int val = 0;
  pinMode(IN, INPUT);
  val = digitalRead(IN);
  if (val == 0)
    //hold for 2 mins
    //hold for 1 sec
  if (val == 1)
      delay(100);
Nathan Litjens
Quoll
I've kept the delays in some spots as I want it to lock on those tasks. I really don't know what to do, so I have tried this.
const int IN = 4;
unsigned long interval = 1000;
unsigned long interval2 = 120000;
unsigned long previousMillis = 0;
int val = 0;
  pinMode(IN, INPUT);
  if (val == 0)
    unsigned long currentMillis = millis();
    if ((unsigned long)(currentMillis - previousMillis) >= interval2)
    previousMillis = millis();
  if (val == 1)
      delay(100);
Not really getting anywhere. >:(
Nathan Litjens
vaj4088
A)  Arduino programmers usually avoid pins 0 and 1 because of the complications caused by sharing with the Serial port.  Please change the pins that are used for CAMERA and SHUTTER.
B)  You have numbered states already.  That is great!  I would suggest that the numbers go 100, 200, 300, etc. so that additional states can easily be added in-between, but it is not important.
C)  Some aspects of your requirements are unclear to me.  For example, what happens if the shutter gets triggered after step 4 in the loop when the CAMERA output is LOW but step 1 of the interruption requirements says that CAMERA should still be HIGH?  What happens after step 4 in the loop?  Step 1?  But this would mean that CAMERA would go LOW only for microseconds.  Is that your intent?
D)  If it were up to me, I would use different numbers in the loop and in the interruption just to avoid confusion, but it is not important.
Quoll
Thanks again,
I will change the pins.
So the numbers are OK as - is?
I don't want any interruption to the loop when the camera output goes LOW for that second, because if it did trigger, the camera would not be ready.
I will try the code again with  different pins and see if it works, but I somehow doubt it.
Thanks
Nathan Litjens
Quoll
Back to the drawing board. I have made the changes to the pins and called the long 2 minute wait "ARMED".
Uploaded the code and all is does is flash the 2 LEDs every second. If I activate the input, it turns the SHUTTER output LOW and holds the CAMERA input high for a second.
I don't know what is wrong or how to fix it
const int CAMERA = 3;
const int SHUTTER = 4;
const int IN = 2;
unsigned long ARMED= 120000;
int val = 0;
  pinMode(IN, INPUT);
  if (val == 0)
    if ((unsigned long)(currentMillis - previousMillis) >= ARMED)
  if (val == 1)
      delay(100);
Nathan Litjens
