It's all out there
https://www.youtube.com/results?search_query=mpu6050+arduino
void read_gyro()
read_mpu_6050_data(); //Read the raw acc and gyro data from the MPU-6050
gyro_x -= gyro_x_cal; //Subtract the offset calibration value from the raw gyro_x value
gyro_y -= gyro_y_cal; //Subtract the offset calibration value from the raw gyro_y value
gyro_z -= gyro_z_cal; //Subtract the offset calibration value from the raw gyro_z value
//Gyro angle calculations
//0.0000611 = 1 / (250Hz / 65.5)
angle_pitch += gyro_x * 0.0000611; //Calculate the traveled pitch angle and add this to the angle_pitch variable
angle_roll += gyro_y * 0.0000611; //Calculate the traveled roll angle and add this to the angle_roll variable
//0.000001066 = 0.0000611 * (3.142(PI) / 180degr) The Arduino sin function is in radians
angle_pitch += angle_roll * sin(gyro_z * 0.000001066); //If the IMU has yawed transfer the roll angle to the pitch angel
angle_roll -= angle_pitch * sin(gyro_z * 0.000001066); //If the IMU has yawed transfer the pitch angle to the roll angel
//Accelerometer angle calculations
acc_total_vector = sqrt((acc_x * acc_x) + (acc_y * acc_y) + (acc_z * acc_z)); //Calculate the total accelerometer vector
//57.296 = 1 / (3.142 / 180) The Arduino asin function is in radians
angle_pitch_acc = asin((float)acc_y / acc_total_vector) * 57.296; //Calculate the pitch angle
angle_roll_acc = asin((float)acc_x / acc_total_vector) * -57.296; //Calculate the roll angle
//Place the MPU-6050 spirit level and note the values in the following two lines for calibration
angle_pitch_acc -= 0.0; //Accelerometer calibration value for pitch
angle_roll_acc -= 0.0; //Accelerometer calibration value for roll
if (set_gyro_angles) { //If the IMU is already started
angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004; //Correct the drift of the gyro pitch angle with the accelerometer pitch angle
angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004; //Correct the drift of the gyro roll angle with the accelerometer roll angle
else { //At first start
angle_pitch = angle_pitch_acc; //Set the gyro pitch angle equal to the accelerometer pitch angle
angle_roll = angle_roll_acc; //Set the gyro roll angle equal to the accelerometer roll angle
set_gyro_angles = true; //Set the IMU started flag
//To dampen the pitch and roll angles a complementary filter is used
angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1; //Take 90% of the output pitch value and add 10% of the raw pitch value
angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1; //Take 90% of the output roll value and add 10% of the raw roll value
void read_mpu_6050_data() { //Subroutine for reading the raw gyro and accelerometer data
Wire.beginTransmission(0x68); //Start communicating with the MPU-6050
Wire.write(0x3B); //Send the requested starting register
Wire.endTransmission(); //End the transmission
Wire.requestFrom(0x68, 14); //Request 14 bytes from the MPU-6050
while (Wire.available() < 14); //Wait until all the bytes are received
acc_x = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the acc_x variable
acc_y = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the acc_y variable
acc_z = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the acc_z variable
temperature = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the temperature variable
gyro_x = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the gyro_x variable
gyro_y = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the gyro_y variable
gyro_z = Wire.read() << 8 | Wire.read(); //Add the low and high byte to the gyro_z variable
Hope that helps.
Forgot to add:
void calibrate_gyro(int cal_points)
lcd.setCursor(0, 0); //Set the LCD cursor to position to position 0,0
lcd.print("Calibrating gyro"); //Print text to screen
lcd.setCursor(0, 1); //Set the LCD cursor to position to position 0,1
for (int cal_int = 0; cal_int < cal_points ; cal_int ++) { //Run this code 2000 times
if (cal_int % (cal_points / 16) == 0)lcd.print("."); //Print a dot on the LCD every 125 readings
gyro_x_cal += gyro_x; //Add the gyro x-axis offset to the gyro_x_cal variable
gyro_y_cal += gyro_y; //Add the gyro y-axis offset to the gyro_y_cal variable
gyro_z_cal += gyro_z; //Add the gyro z-axis offset to the gyro_z_cal variable
delay(3); //Delay 3us to simulate the 250Hz program loop
gyro_x_cal /= cal_points; //Divide the gyro_x_cal variable by 2000 to get the avarage offset
gyro_y_cal /= cal_points; //Divide the gyro_y_cal variable by 2000 to get the avarage offset
gyro_z_cal /= cal_points; //Divide the gyro_z_cal variable by 2000 to get the avarage offset
Serial.print("gyro_x_cal:");
Serial.println(gyro_x_cal);
Serial.print("gyro_y_cal:");
Serial.println(gyro_y_cal);
Serial.print("gyro_z_cal:");
Serial.println(gyro_z_cal);
