Hi All,
I have connected 3 MB1003 ultrasonic sensors which are placed 60 cm apart from each other on the ceiling. The sensors are placed at an angle of 90 degree facing the floor.
The connections are made as per the datasheet
Here is my code
const int anPin1 = 0;
const int anPin2 = 1;
const int anPin3 = 2;
int triggerPin1 = 2;
long distance1, distance2, distance3;
long mm1, mm2, mm3;
long cm1, cm2, cm3;
Serial.begin(9600); // sets the serial port to 9600
pinMode(triggerPin1, OUTPUT);
void start_sensor(){
digitalWrite(triggerPin1,HIGH);
delay(96);
digitalWrite(triggerPin1,LOW);
void read_sensors(){
distance1 = analogRead(anPin1);
mm1=distance15;
cm1=mm1/10;
distance2 = analogRead(anPin2);
mm2=distance25;
cm2=mm2/10;
distance3 = analogRead(anPin3);
mm3=distance3*5;
cm3=mm3/10;
void print_all(){
Serial.print(cm1);Serial.print(",");
Serial.print(cm2);Serial.print(",");
Serial.print(cm3);Serial.print(",");
Serial.println();
start_sensor();
read_sensors();
print_all();
delay(100);
Can anyone suggest me on whats wrong that I am doing?
