Hello all, first and foremost, congrats on what seems to be a tight and productive network. That said, I have a basic code I need written. It has to do with a user set time based on a hall effect sensor movement/duration which will be stored as a comparison to trigger on output voltage to a solenoid.
Yes of course there are details which I have written in Human language...lol. If this is the correct forum for obtaining assistance please do not hesitate to let me know how I should proceed.
In addition I was trying to learn (faster education) how coding works by GUI block programs, if this is a good starting point for my purposes could you recommend one. I am not savvy in the ways of generation yet, but I can read and interpret a written code to some degree.
Any question please advise
Be well
gil
PS.
yes a freelancer can seek me out.
The following is my beginners description of what I need coded into an Arduino Uno
Requirement for timing and triggering program to be as follows.
Activating of Customization & Learning mode – AC&LM
- Hall Effect Sensor A (HES-A) activation by user engaging sensor HES - A for a count of 1-second
on, 1 second off, 1 second on, and final off within 6 seconds; This will activate the C&LM - The system requires a failsafe that will return to Normal Operating Mode (NOM) and exiting C&LM
programming when a count of 600 seconds has elapsed - The user must complete the C&LM process within this 600 second period, failing to do so will
require the user to return to the AC&LM programing as indicated above. - When and during the C&LM process, a steady ON Output to a Red led to indicate that the system is
currently in C&LM. - The purpose of this mode is to activate Hall Effect Sensor B (HES-B) from its normal operating
mode as a motion timer and comparator, into that of a recording sensor based on elapsed time,
which will then be recorded and store as the new user entered period.
Customization & Learning Mode – C&LM
1 While in CLM (Red Led Steady On) the ON motion state or time period of HES-B will be recorded to
memory for future comparison in Normal Operation Mode.
2 If no action is taken or if HES-B duration time has not been recorded within the 600 second failsafe
period, the CLM will terminate and the system will revert to the factory 300 second HES-B period
3 A successful CLM will conclude when the HES-B input duration has been recorded as indicated when
a conclude or a stop motion from HES-B.
4 This period must exceed 120 seconds and cannot exceed a high limit of 300 seconds in order to be
accepted.
5 If and when the HES-B is properly configured as indicate above, the system will toggle the Red LED
from steady on to flashing in intervals of 2 seconds for six cycles and then conclude the CLM and
return to NOM.
6 CLM termination can only occur if satisfactory CLM has been performed as indicated above and/or if
CLM time period exceeds 600 seconds.
Normal Operational Mode - NOM
- In NOM the Red led will flash once every 60 seconds
- The HES-B will monitor the movement duration proximity of a magnet.
- If and when HES-B detects motion, it will trigger a countdown timer which will be compared to the
CLM recorder duration or Factory Preset period of 300 seconds. - If and/or when the HES-B detects that the preset countdown time has exceeded the comparison
time, the coding need send out a 5v output to a micro solenoid coil. - This micro solenoid output voltage, when triggered, need be set to hold for a duration between 10
to 20 seconds; the system will then be in a triggered mode TM - If HES-B motion countdown time does not exceed the programmed set point the system will loop
reset back and return to the standby monitoring mode. - While in NOM a momentary and independent output of 5 volts to the micro solenoid need be coded,
one that will trigger once every 24 hours for a duration between 2 to 10 seconds - This automatic trigger must be ignored or excluded if the system is in either C&LM or during a
HES – B countdown period. - This Output can also be excluded if any output to Solenoid has been triggered within the
24hour period - A Battery Voltage monitor which will trigger and flash the Red led 1 second on and 6 seconds off, if
and when the supply voltage should drop below 11 volts. This low battery indicator will remain in
effect until battery voltage requirement is met; ie 11+ volts
Triggered Mode – TM
- When in TM Mode an output Voltage to solenoid will trigger every 60 seconds for a duration of 10
seconds - Output to RED led placed in strobe mode with on/off every 10 seconds
- In order to exit from TM user must activate HES-A for 10 seconds on, this will then return the
system to NOM until a future trigger occurs.
Modes:
AC&LM
Activation of Customization & Learning Mode
C&LM
NOM
TM
Triggered Mode
Inputs:
HES – A
Hall Effect Sensor A – User access to C&LM and permits user to activate Reset Mode
HES – B
Hall Effect Sensor B – Triggers countdown timer and compares with stored time
Voltage Sensor
Internal Voltage monitor which triggers led when voltage reaches below 11vs.
Outputs:
Solenoid Voltage
Output voltage to engage solenoid as indicated above
Red Led
LED to indicate state of system by flashing frequency as indicated above
Storage Data:
Default or factory set comparison time of 300 seconds which can be customized to new period if and when programmed as described in C&LM section
I accept constructive criticism well, so please if Im barking up the wrong tree please advise
