I am writing a routeen to send nzri data out one of the ports using timer 1 as a time base and written a delay process as the standard delay re configures timer 1;
if I have a while loop waiting for a counter set by the timer interrupt it never ends however it I toggle a pin in the while loop it works as expected.
int timer;
void setup(){
//set timer1 interrupt at 9600Hz
TCCR1A = 0;// set entire TCCR2A register to 0
TCCR1B = 0;// same for TCCR2B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 8khz increments
OCR1A = 207;// = (1610^6) / (96008) - 1 (must be <256)
// turn on CTC mode
TCCR1A |= (1 << WGM21);
// Set CS21 bit for 8 prescaler
TCCR1B |= (1 << CS21);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE2A);;
sei(); //enable interrupts
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
void delay_time(int Timer) {
int Time=Timer*3913;
timer=0;
while(Time>timer){
digitalWrite(9,digitalRead(9) ^ 1); // if this line is commented out the while never exits
digitalWrite(10,digitalRead(10) ^ 1);
ISR(TIMER1_COMPA_vect){//timer1 interrupt 9600hz toggles pin 9
timer++;
//other thing to happen at a regular basis
as it freezes/blocks your code from doing other things
As general "making small talk to get points, OK.
Not applicable in this case - the only "thing" the code does is to monitor temperature and controls the fan. KISS
Hera are some different ways to accomplish the task. Suggesting to add another while loop to keep the motor off for selected time and still keep checking the temp.
IN PSEUDOCODE not to be cut and paste !
int sensor = A0; //temp sensor on pin A0
int temp = 0; //do not change
int relay = 5; //relay is on pin 5
pinMode(sensor, INPUT); //set sensor as input
pinMode(relay, OUTPUT); //set relay as output
// temp = analogRead(sensor); //read the value from the sensor
if (analogRead(sensor) >= 80) // If temp is 80 or above
temperature while loop
while (analogRead(sensor) > 70) { // and Until temp is below 70
digitalWrite(relay, HIGH ); // turn relay on
turn the relay off
get start time to keep relay off
relay off wait loop
while (current time - start time < motor off time & (analogRead(sensor) < ? temp ? ))
; keep motor off and keep checking temp
digitalWrite(relay, LOW); //Turn relay off and restart loop
And I hope your code is indented properly. Without code tags, all the leading spaces are removed. Type control-T in the IDE editor to format it before posting.
To answer your question, you must use the volatile attribute on variables that are shared between interrupt routines and non-interrupt code (e.g., loop or anything called from loop).
pggood:
If you have a WHILE loop waiting to be interrupted then you should not have a WHILE loop in the first place.
Use IF and allow loop() to take care of the iteration.
In general don't use WHILE or FOR loops unless they do something that completes in a few microsecs.
Select the pasted code (mouse click-drag-release OR control-A).
Click "</>" button in upper left (adds code tags around selected text).
Enter extra descriptive text before or after code tags.
Click "Post" or "Preview" button in lower left (interprets tags to show code in white box).
If you're mouse-averse, you can just type left bracket, c, o, d, e, and right bracket before the code. Then arrow down to the end of the code and type left bracket, slash, c, o, d, e and right bracket after the code.
Example:
**IN PSEUDOCODE not to be cut and paste !
[nobbc][code]int sensor = A0; //temp sensor on pin A0
etc.
[/code][/nobbc]
-dev:
Duplicate question, already answered over here.
How many answers do you want?
What?
Copy the code (control-C) from somewhere.
Paste the code (control-V) into the post editor.
Nope,
Example:
etc.
[/code][/nobbc]
...more commentary...**
NOPE,
KISS
properly posted code in code tags has an option to "Select" and then "copy' via mouse .
Next using "paste" via mouse into Quick reply form LOSSES the code tags.
Where have you been in past x years? Suggesting to use "control C / Control V " in graphic environment is archaic.
Here - with three (3!) mouse clicks - no code tags
volatile int timer;
And the answer is - it is my , Arduino customer , fault !
