Hi folks, summarizing from above, this is the minimal setup for using a two pin encoder as a knob on channel TC 0, Channel 0:
pmc_enable_periph_clk(ID_TC0);
TC_Configure(TC0,0, TC_CMR_TCCLKS_XC0);
TC0->TC_BMR = TC_BMR_QDEN // Enable QDEC (filter, edge detection and quadrature decoding)
| TC_BMR_POSEN // Enable the position measure on channel 0
//| TC_BMR_EDGPHA // Edges are detected on PHA only
//| TC_BMR_SWAP // Swap PHA and PHB if necessary (reverse acting)
| TC_BMR_FILTER // Enable filter
| TC_BMR_MAXFILT(63) // Set MAXFILT value
// Enable and trigger reset
TC0->TC_CHANNEL[0].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN;
int16_t count = REG_TC0_CV0;
This will return a positive or negative count. Note it will roll over at plus or minus 32767. In theory, you can avoid rollover by resetting the count to zero by calling
But in reality, this does not seem to quite get back to zero all the time. I just check to see if I am above 32000, or below -32000, and reset.
Hope this helps.
Doug
