I am trying to develop a project in which if the DUST SENSOR detects the DUST density to be more than
40 ug/m3 then it would flick the Servo motor to flick the Switch ON and vice-versa.
This is the code for it.
I have attached a schematic of the DUST SENSOR with the ARDUINO UNO R3 only. Else the Servo Motor Schematic could be easily understood. I tried it connecting it with my laptop but I think there is a voltage division problem. I am new to Arduino. Please help soon.
// Sharp GP2Y1014AU0F Dust Sensor Demo
// Board Connection:
// GP2Y1014 Arduino
// V-LED Between R1 and C1
// LED-GND C1 and GND
// LED Pin 7
// S-GND GND
// Vo A5
// Vcc 5V
// Serial monitor setting:
// 9600 baud
// Choose program options.
//#define PRINT_RAW_DATA
#define USE_AVG
#include<Servo.h>
// Arduino pin numbers.
const int sharpLEDPin = 7; // Arduino digital pin 7 connect to sensor LED.
const int sharpVoPin = A5; // Arduino analog pin 5 connect to sensor Vo.
int servoPin = 3;
Servo Servol;
// For averaging last N raw voltage readings.
#ifdef USE_AVG
#define N 100
static unsigned long VoRawTotal = 0;
static int VoRawCount = 0;
#endif // USE_AVG
// Set the typical output voltage in Volts when there is zero dust.
static float Voc = 0.6;
// Use the typical sensitivity in units of V per 100ug/m3.
const float K = 0.5;
// Helper functions to print a data value to the serial monitor.
void printValue(String text, unsigned int value, bool isLast = false) {
Serial.print(text);
Serial.print("=");
Serial.print(value);
if (!isLast) {
Serial.print(", ");
void printFValue(String text, float value, String units, bool isLast = false) {
Serial.print(text);
Serial.print("=");
Serial.print(units);
if (!isLast) {
Serial.print(", ");
// Arduino setup function.
// Set LED pin for output.
pinMode(sharpLEDPin, OUTPUT);
// Start the hardware serial port for the serial monitor.
// Wait two seconds for startup.
delay(2000);
Serial.println("");
Serial.println("GP2Y1014AU0F Demo");
Serial.println("=================");
Servol.attach(servoPin);
// Arduino main loop.
// Turn on the dust sensor LED by setting digital pin LOW.
digitalWrite(sharpLEDPin, LOW);
// Wait 0.28ms before taking a reading of the output voltage as per spec.
delayMicroseconds(280);
// Record the output voltage. This operation takes around 100 microseconds.
int VoRaw = analogRead(sharpVoPin);
// Turn the dust sensor LED off by setting digital pin HIGH.
digitalWrite(sharpLEDPin, HIGH);
// Wait for remainder of the 10ms cycle = 10000 - 280 - 100 microseconds.
delayMicroseconds(9620);
// Print raw voltage value (number from 0 to 1023).
#ifdef PRINT_RAW_DATA
printValue("VoRaw", VoRaw, true);
Serial.println("");
#endif // PRINT_RAW_DATA
// Use averaging if needed.
float Vo = VoRaw;
#ifdef USE_AVG
VoRawTotal += VoRaw;
VoRawCount++;
if ( VoRawCount >= N ) {
Vo = 1.0 * VoRawTotal / N;
VoRawCount = 0;
VoRawTotal = 0;
return;
#endif // USE_AVG
// Compute the output voltage in Volts.
Vo = Vo / 1024.0 * 5.0;
printFValue("Vo", Vo*1000.0, "mV");
// Convert to Dust Density in units of ug/m3.
float dV = Vo - Voc;
if ( dV < 0 ) {
dV = 0;
Voc = Vo;
float dustDensity = dV / K * 100.0;
printFValue("DustDensity", dustDensity, "ug/m3", true);
Serial.println("");
if(dustDensity<=40)
Servol.write(180);
Servol.write(0);
} // END PROGRAM
Thanks,
KRISH.
