So, I have this idea to use analog input to read the voltage shift difference on the system.
The Idea is simple, I will detect the zero value of each wave then calculate duration before the second wave hit the zero value (like suggested on Joe G on this article .
This is a fixed 50Hz electricity that I am measuring.
Using this function:
float getPs(){ //get Phase shift
boolean boom=true;
uint32_t psStart;
uint32_t psStop ;
while (boom==true){
int v1Ps = analogRead(A0);
boolean counting = false;
//detect when v1=0
if (v1Ps == 511) { //511 is the y=0 point of the measured wave
counting = true;
noInterrupts(); //for precision
psStart = micros(); //record startingtime
while (counting == true) {
while (micros()-psStart<= 5000){ // this is the voltage shift limit which is 90degrees (5ms of 20ms Period) so the code will not read any zero value that occured after 5000us
int v2Ps = analogRead(A1); //read 2nd port for other wave
if (v2Ps==511){
psStop = micros();
counting=boom = false; //breaking the loops
interrupts();
readPs = psStop - psStart; //read value got subtracted
return readPs;
But the value i got from reading it was:
[code]
548
556
556
556 <-- I try to shift the phase here. nothing changed
548
556
548
556
548
[/code]
the problem is that these code doesnt respond to any phase displacement I made.
anyone could help?
if tried reading these article1, article2, and many other article about voltage shift, but they seems to be needing other hardware that I cant make (I'm bad at electronics, and also I already overbudgeted for this project). i.e making ZCD and using the digital pin, or have something I dont understand how to apply.
Please help, any kind of suggestion would be appreciated.
If the frequency is a constant and you know when zero crossing occurs, then it is math to know at what moment what the phase angle will be from zero crossing.
detect crossings by the sign reversing, not by comparing a specific value
interpolate between sample instants to get fine-grained zero-crossing times - for instance
if the value goes 20,5,-10,-25 you know the crossing point was 1/3 of a sample period after reading
the 5.
Note that 2) and 3) can be done in a single routine that compares the latest value to the previous one,
and using the value of micros() for both samples allows a micro-second resolution time measurement
(best case theoretical).
do not assume rising and falling crossings are exactly 180 degrees apart, either just use one
kind of crossing, or separately measure phase difference with each and average the two.
One obvious error is that you did not declare the variables written to in the ISRs as volatile. So that'd be at least i, j (terrible names for global variables) and the two time arrays. Maybe more, I didn't analyse in detail.
Next, you should do the math in loop(), not in the ISR. Don't do anything more in the ISR than what strictly has to be there. Set a flag so loop() can see there's data available. For responsiveness to this data, get rid of that delay(100).
if (freq1 == freq2) {
It's extremely rare for float values to be exactly the same, unless they're set to zero or so (which in your case would happen if both period variables are zero). You normally compare floats by taking the difference, and checking whether that's smaller than an offset.
This are basic programming issues - I didn't check the algorithm you used, MarkT commented on that already in #5.
