Hello, I am currently working on a project that uses an arduino uno R3 to run a 24v DC motor that pulls 4.5A. My question is, how do you determine what MOSFET to use?
I tried to use http://www.digikey.com/product-search/en?x=-1147&y=-73&lang=en&site=us&KeyWords=huf75639p3-nd but it quickly over heated.
the max gate voltage applied is 4v. (ranges from 2-4v). attached is a crudely drawn (sorry) section of the schematic dealing with the motor.
any help would be appreciated.
thanks,
-Jim
24V motor controller drawing.pdf (12.7 KB)
That parts looks capable.
Try lowering the gate resistor to 150mA so the MOSFET is switched on/off faster.
any help would be appreciated, I posted this in general electronics, but I figured motors may be a better place to post this.
thanks,
-Jim
That part looks capable. Try lowering the gate resistor to 150 ohm so the MOSFET switches on/off faster.
P=I^2R = 4.5 4.5*.025 = 500mW, maybe put a heatsink on it as well.
Thanks, I will try that now.
Thanks for replying to this one as well!
I am in the middle of lowering the gate resistor. I am a little confused as to where the R = .025 came from though?
I have a beefy heatsink on it at the moment http://www.digikey.com/product-search/en?x=-1147&y=-73&lang=en&site=us&KeyWords=ra-t2x-51e-nd
sorry for the noob question, still learning.
im sorry, i see the 25 Mohm on the part now.
mOhm (0.025), not MOhm (25,000,000). Units matter.
A flyback diode would be appropriate as well.
system
July 9, 2013, 8:05pm
10
Thanks for the correction, I will be more careful.
I am very new to MOSFETs how would you go about lowering the gate resistor to 150 ohm.
Would I add a resistor from the gate pin to the source pin? Should I calculate it like the resistors are in parallel?
You show a 1K in your diagram from Arduino pin 3 to the MOSFET gate. Change it to 150.
system
July 9, 2013, 8:18pm
12
thanks, I actually do have a flyback diode attached, I just failed to draw it in. //fail
Thanks for all the help!
dc42
July 9, 2013, 8:21pm
13
Sorry, that part is definitely not suitable for driving direct from the Arduino, because it's not a logic-level mosfet. You need to pick a mosfet that has a low Rds(on) quoted at Vgs=4.5V (not 10V as for that part), such as IRLU8726pbf. And you definitely need to use a flyback diode.
system
July 9, 2013, 8:22pm
14
// slaps forehead.
Thanks, sorry for the silly question. I have been way overthinking this.
Trying it now, will have results in a few min
Ok, will check later, gotta run.
system
July 9, 2013, 8:35pm
16
I let the motor run for a while, I used a infrared thermometer and the mosfet/heatsink was reading around 190 F =(
system
July 9, 2013, 8:38pm
17
thanks, I see that Digi-Key has IRLU8726pbf in stock, will order a few now.
I do have a flyback diode, I just forgot to draw it in the schematic, my bad.
system
July 9, 2013, 8:41pm
18
I did notice that the max power for the IRLU8726pbf is 75W. Is that going to be enough? I thought I would need something over 100W. 24v * 4.5A = 108W
or does the max power mean something else?
No the power is what it will dissipate not what it switches.
Find the power from I2 R where R is the on resistance of the FET.
You know cross posting pisses people off here. It is bad MANNORS.
