WS2812 VU meter
I was looking for a nice VU meter using the WS2812 LED Strip and found a link which I cannot remember to accredit but the code was limited to 50 LEDs so I have a play around and not it was address the limits of the Adafruit_NeoPixel.h library.
Enjoy.
Youtube link
Just connect the audio source to GND and analoge pin A1 and then the LED to power and D2
Enjoy
#define PIN 2
#define lightCount 144
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream
//   NEO_HZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(lightCount, PIN, NEO_GRB + NEO_KHZ800);
//fadeThickness = 0;  // CHANGE THICKNESS (0-10)
int vol = 0;
float total = 0;
int fadeCol = 0;
int val[25];
int volLast = 0;
int fadeAmt = 0;
int counter = 0;
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
// Serial.begin(9600);
  fadeCol = 0;
total = 0;
  for (int i = 0; i < lightCount; i++){
      counter = 0;
       do{
      vol = analogRead(A1);
      counter = counter + 1;
      if (counter > 500){
         rainbowCycle(10);
    }while (vol == 0);
    total = total + vol;
  vol = total / 80;
// Serial.println(vol);
  vol = map(vol,20,255,0,20);
  if (volLast > vol) {
    vol = volLast - 4;
  volLast = vol;
  fadeAmt = 0;
// Serial.print(vol);
  for (int i = 0; i<strip.numPixels()/2;i++){
    if (i < vol){
         strip.setPixelColor((i+strip.numPixels()/2), strip.Color(0,255,vol));
         strip.setPixelColor((strip.numPixels()/2-i), strip.Color(0,255,vol));
    else if (i < (vol + 8)) {
         strip.setPixelColor((i+strip.numPixels()/2), strip.Color(255,vol,vol));
         strip.setPixelColor((strip.numPixels()/2-i), strip.Color(255,vol,vol));
         strip.setPixelColor((i+strip.numPixels()/2), strip.Color(0,0,255));
         strip.setPixelColor((strip.numPixels()/2-i), strip.Color(0,0,255));
  strip.show();
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
     vol = analogRead(A0);
     if (vol> 10) {
      return;
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Excellent many thanks, I tried it and it worked, very simple code. I would like to know which is the line that defines the audio input, I want to implement it in another code that I got and change that part since the other code I have uses a microphone and I want to connect it directly with this one, from now on, thank you very much, I hope you can help, greetings!
I am totally new in Arduino, just playing with some LEDS and building some projects I found in YouTube.
I took a 'Sound Sensor Module KY-038' and tried to connect it with a RGB 5V LED strip with 12 leds through an Arduino Uno. I tried several codes found on the Internet but nothing seems to work.
I connect the strip input and mic input to D6 on Uno. I connect the AO of the mic to A0 on Uno.
The mic also has a DO but I don't use it.
The project I am on is like this:
The code is so long that I had to write the link to it:
When I run the code the led strip lights all blue and only the last LED seems to flash in blueish formats only when sound change. I did changed the code to set the number of leds i am using from 150 to 12.
Any help? I really need it!
Wat kind of mic do you use? Some are comming with a dc-offset.
#define micPin  1 //Your mic pin
Serial.println(analogRead(micPin));
Open serial plotter and look wat is your avarage signal (at silence).
@ the sound_reactiive.ino, change this part with your readings.
//Confirmed microphone low value, and max value
#define MIC_LOW 0.0
#define MIC_HIGH 737.0
Here is some code I have using the DFRobot Sound Analyzer as an input source to generae LED lighting:
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "AudioAnalyzer.h"
/* define event group and event bits */
EventGroupHandle_t eg;
#define evtDo_AudioReadFreq       ( 1 << 0 ) // 1
TickType_t xTicksToWait0 = 0;
QueueHandle_t xQ_LED_Info;
const int NeoPixelPin = 26;
const int LED_COUNT = 24; //total number of leds in the strip
const int NOISE = 150; // noise that you want to chop off
const int SEG = 6; // how many parts you want to separate the led strip into
const int SerialDataBits = 115200;
const int Priority4 = 4;
const int TaskStack40K = 40000;
const int TaskCore1  = 1;
const int TaskCore0 = 0;
const int AudioSampleSize = 6;
const int Brightness = 180;
const int A_D_ConversionBits = 4096; // arduino use 1024, ESP32 use 4096
Analyzer Audio = Analyzer( 5, 15, 36 );//Strobe pin ->15  RST pin ->2 Analog Pin ->36
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
Adafruit_NeoPixel leds = Adafruit_NeoPixel( LED_COUNT, NeoPixelPin, NEO_GRB + NEO_KHZ800 );
int FreqVal[7];//create an array to store the value of different freq
  eg = xEventGroupCreate();
  Serial.begin( SerialDataBits );
  Audio.Init(); // start the audio analyzer
  leds.begin(); // Call this to start up the LED strip.
  clearLEDs();  // This function, defined below, de-energizes all LEDs...
  leds.show();  // ...but the LEDs don't actually update until you call this.
  xQ_LED_Info = xQueueCreate ( 1, sizeof(FreqVal) );
  xTaskCreatePinnedToCore( fDo_AudioReadFreq, "fDo_ AudioReadFreq", TaskStack40K, NULL, Priority4, NULL, TaskCore1 ); //assigned to core
  xTaskCreatePinnedToCore( fDo_LEDs, "fDo_ LEDs", TaskStack40K, NULL, Priority4, NULL, TaskCore0 ); //assigned to core
  xEventGroupSetBits( eg, evtDo_AudioReadFreq );
} // setup()
void loop() {} // void loop
void fDo_LEDs( void *pvParameters )
  int iFreqVal[7];
  int j;
  leds.setBrightness( Brightness ); //  1 = min brightness (off), 255 = max brightness.
  for (;;)
    if (xQueueReceive( xQ_LED_Info, &iFreqVal,  portMAX_DELAY) == pdTRUE)
      j = 0;
      //assign different values for different parts of the led strip
      for (j = 0; j < LED_COUNT; j++)
        if ( (0 <= j) && (j < (LED_COUNT / SEG)) )
          set(j, iFreqVal[0]); // set the color of led
        else if ( ((LED_COUNT / SEG) <= j) && (j < (LED_COUNT / SEG * 2)) )
          set(j, iFreqVal[1]); //orginal code
        else if ( ((LED_COUNT / SEG * 2) <= j) && (j < (LED_COUNT / SEG * 3)) )
          set(j, iFreqVal[2]);
        else if ( ((LED_COUNT / SEG * 3) <= j) && (j < (LED_COUNT / SEG * 4)) )
          set(j, iFreqVal[3]);
        else if ( ((LED_COUNT / SEG * 4) <= j) && (j < (LED_COUNT / SEG * 5)) )
          set(j, iFreqVal[4]);
          set(j, iFreqVal[5]);
      leds.show();
  vTaskDelete( NULL );
} // void fDo_ LEDs( void *pvParameters )
void fDo_AudioReadFreq( void *pvParameters )
   // int64_t EndTime = esp_timer_get_time();
   // int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
  for (;;)
      xEventGroupWaitBits (eg, evtDo_AudioReadFreq, pdTRUE, pdTRUE, portMAX_DELAY);
      Audio.ReadFreq(FreqVal);
      for (int i = 0; i < 7; i++)
        FreqVal[i] = constrain( FreqVal[i], NOISE, A_D_ConversionBits );
        FreqVal[i] = map( FreqVal[i], NOISE, A_D_ConversionBits, 0, 255 );
      xQueueSend( xQ_LED_Info, ( void * ) &FreqVal, xTicksToWait0 );
} // fDo_ AudioReadFreq( void *pvParameters )
//the following function set the led color based on its position and freq value
void set(byte position, int value)
  // segment 0, red
  if ( (0 <= position) && (position < LED_COUNT / SEG) ) // segment 0 (bottom to top), red
    if ( value == 0 )
      leds.setPixelColor( position, 0, 0, 0 );
      leds.setPixelColor( position, leds.Color( value , 0, 0) );
  else if ( (LED_COUNT / SEG <= position) && (position < LED_COUNT / SEG * 2) ) // segment 1 yellow
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color(0, 0, 0));
      leds.setPixelColor(position, leds.Color( value, value, 0)); // works better to make yellow
  else if ( (LED_COUNT / SEG * 2 <= position) && (position < LED_COUNT / SEG * 3) ) // segment 2 pink
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( value, 0, value * .91) ); // pink
  else if ( (LED_COUNT / SEG * 3 <= position) && (position < LED_COUNT / SEG * 4) ) // seg 3, green
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( 0, 0, 0));
    else //
      leds.setPixelColor( position, leds.Color( 0, value, 0) ); //
  else if ( (LED_COUNT / SEG * 4 <= position) && (position < LED_COUNT / SEG * 5) ) // segment 4, leds.color( R, G, B ), blue
    // Serial.println( position );
    if ( value == 0 )
    else //
      leds.setPixelColor(position, leds.Color( 0, 0, value) ); // blue
  else // segment 5
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( 0, 0, 0)); // only helps a little bit in turning the leds off
      leds.setPixelColor( position, leds.Color( value, value * .3, 0) ); // orange
} // void set(byte position, int value)
void clearLEDs()
  for (int i = 0; i < LED_COUNT; i++)
    leds.setPixelColor(i, 0);
} // void clearLEDs()
You can just ignore the ESP32 OS code.
This will damage the Arduino. Audio signals are AC and the negative parts of signal will damage the analog pin.
I changed the MIC_LOW and MIC_HIGH to 530 and 630 respectively.
The 10 first leds are always on. The others are following the volume nicely. But they are all blue.
I testet it and end up with blue led´s only.
There is a for loop who makes all the changes, but i dont figure out wat is wrong.
I testet this one:
This one is working for me.
Things you have to change:
#define DC_OFFSET  -260  // DC offset in mic signal - if unusure, leave 0
For you its possible -510
#define N_PIXELS  144  // Number of pixels in strand
For you should be 12.
#define MIC_PIN   A0  // Microphone is attached to this analog pin
#define LED_PIN    6  // NeoPixel LED strand is connected to this pin
You should understand it by yourself :slight_smile: .
const int buttonPin = A2;     // the number of the pushbutton pin
There are multible VU-Meter you can switch with a button to GRD.
