Hi all,
hoping someone has the magic idea here - I got stuck with this one.
I'm trying to use a (currently unknown) DallasTemperature sensors. Got the latest Arduino 1.0.1 compatible libraries for DT sensors and for oneWire, all set.
I'm trying to setup an array of these sensors, such as
#include <DallasTemperature.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 7
OneWire oneWire(ONE_WIRE_BUS); // start OneWire interface on digital pin 7
#define SensorCount 5
// typedef uint8_t DeviceAddress[8];
DeviceAddress tmp; // a device address
DeviceAddress DevAddress[SensorCount]; // an array of 5 device addresses
DallasTemperature Sensors(&oneWire); // hookup sensors via oneWire interface
void setup(){
// setup serial speed for serial monitor
// setup DallasTemperature Sensors
// start sensor library
Sensors.begin();
// find sensors by searching oneWire bus
oneWire.reset_search();
for (int i=0; i<SensorCount-1; i++)
// assigns the next address found to tmp
if (!oneWire.search(tmp)) // store whatever found in tmp
// oops ... fault
// success
DevAddress[i] = tmp;
Sensors.setResolution(12); // 12 bit, 0.06 deg C
Alas, it doesnt compile... with
sketch_mar01a.cpp: In function ‘void setup()’:
sketch_mar01a.cpp:61:23: error: invalid array assignment
I think part of the cause of the problem is that the DallasTemperature class (DallasTemperature.h) defined the type DeviceAddress as an array, and I am somehow pointing to the wrong parts of it:
So that means my
is actually a
uint8_t DevAddress[8][SensorCount];
or a
uint8_t DevAddress[SensorCount][8];
which it doesn't like.
So my main question is - any ideas on how to define an array of addresses, each address pointing to a DeviceAddress which really is an array of [8] uint8_t's ? I've tried defining and array of pointers, such as
DeviceAddress* devAddress[SensorCount]
tmp = new DeviceAddress;
devAddress[i] = tmp;
but that only produces garbage as well ...
Any clever ideas?
Thanks in advance,
Otte
