Hello All,
I started over here: Interrupts not working when in sleep mode · Issue #84 · MCUdude/MegaCore · GitHub but it seems to either be a manufacturing problem or a board lib problem.
Essentially on the atmega2560, using the sample wake from sleep code here: Arduino Playground - ArduinoSleepCode
If you enable the internal pull-up resistor on whatever pin you're dealing with and try to use the FALLING edge to wake the micro, it will not wake, but if you use LOW it will.
Edit: I tested on two different chips with date codes:
16AU 1616
16AU 1726
Thanks,
