shift registers
how would I wire up this circuit with a shift register preferably the 74HC164 and how would i change the code for it
http://arduino.cc/playground/Main/DirectDriveLEDMatrix
 * Conway's "Life"
 * Adapted from the Life example
 * on the Processing.org site
 * Needs FrequencyTimer2 library
#include <FrequencyTimer2.h>
byte col = 0;
byte leds[8][8];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
#define DELAY 0
#define SIZE 8
extern byte leds[SIZE][SIZE];
byte world[SIZE][SIZE][2];
long density = 50;
  setupLeds();
  randomSeed(analogRead(5));
  for (int i = 0; i < SIZE; i++) {
    for (int j = 0; j < SIZE; j++) {
      if (random(100) < density) {
        world[i][j][0] = 1;
      else {
        world[i][j][0] = 0;
      world[i][j][1] = 0;
  // Display current generation
      leds[i][j] = world[i][j][0];
  delay(DELAY);
  // Birth and death cycle
  for (int x = 0; x < SIZE; x++) {
    for (int y = 0; y < SIZE; y++) {
      // Default is for cell to stay the same
      world[x][y][1] = world[x][y][0];
      int count = neighbours(x, y);
      if (count == 3 && world[x][y][0] == 0) {
        // A new cell is born
        world[x][y][1] = 1;
      if ((count < 2 || count > 3) && world[x][y][0] == 1) {
        // Cell dies
        world[x][y][1] = 0;
  // Copy next generation into place
      world[x][y][0] = world[x][y][1];
int neighbours(int x, int y) {
 return world[(x + 1) % SIZE][y][0] +
         world[x][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][y][0] +
         world[x][(y + SIZE - 1) % SIZE][0] +
         world[(x + 1) % SIZE][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][(y + 1) % SIZE][0] +
         world[(x + SIZE - 1) % SIZE][(y + SIZE - 1) % SIZE][0] +
         world[(x + 1) % SIZE][(y + SIZE - 1) % SIZE][0];
void setupLeds() {
  // sets the pins as output
  for (int i = 1; i <= 16; i++) {
    pinMode(pins[i], OUTPUT);
  // set up cols and rows
  for (int i = 1; i <= 8; i++) {
    digitalWrite(cols[i - 1], LOW);
    digitalWrite(rows[i - 1], LOW);
  clearLeds();
  // Turn off toggling of pin 11 and 3
  FrequencyTimer2::disable();
  // Set refresh rate (interrupt timeout period)
  FrequencyTimer2::setPeriod(2000);
  // Set interrupt routine to be called
  FrequencyTimer2::setOnOverflow(display);
void clearLeds() {
  // Clear display array
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      leds[i][j] = 0;
// Interrupt routine
void display() {
  digitalWrite(cols[col], LOW);  // Turn whole previous column off
  col++;
  if (col == 8) {
    col = 0;
  for (int row = 0; row < 8; row++) {
    if (leds[col][7 - row] == 1) {
      digitalWrite(rows[row], LOW);  // Turn on this led
    else {
      digitalWrite(rows[row], HIGH); // Turn off this led
  digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
Follow its datasheet:
With 4 mA output drive it won't be very bright. And without the output stage latches or an output enable pin all the outputs will appear to flicker as you load in data.
CrossRoads:
http://www.ti.com/lit/ds/symlink/sn74hc164.pdf
ok what chip should i use and how can i change the code for that
Well... use a 74HC595. It got a latch, a clock, enable, reset and it got 9 output. The code is : shiftOut(). Look it up.
