when i connect uno to laptop it says most times " usb device is not recognized" and little times it defined !
I can't understand what's the problem .. ( windows 10) :o
Don't use USB 3 if you can avoid it as there are known issues.
Stick to USB 2.0.
anilkunchalaece:
Try to install the drivers as shown here
Thanks for your Answer , But in fact sometimes my Uno works well and some other times it says usb is not reckon ! Is it windows 10 issue ?
Abdelrhman_Safwat
That the issue is random in your case it would suggest one of three things.
- Bad USB cable
- Faulty USB port (computer or board)
- Faulty board
Swap cables or try another computer or get another board if inspecting yours does not find any issues.
ballscrewbob:
Abdelrhman_SafwatThat the issue is random in your case it would suggest one of three things.
- Bad USB cable
- Faulty board
Thanks brother for your reply
i have upgraded my IDE to the latest and it's good for now .. but how can i solve the problem if it's from the board ... what's your suggestion
If its a board check for bad soldering or loose connection and fix if you can.
Re-loading a bootloader is not likely to fix it so I don't think I would bother going that route.
Very hard to say exactly.
ballscrewbob:
Re-loading a bootloader is not likely to fix it so I don't think I would bother going that route.Very hard to say exactly.
Thanks Brother .... actually after trying many methods i found out the cable was the problem
anilkunchalaece:
This could work if the Arduino is not recognized as USB device at all. But what about if it recognized as a no functioning USB device? I couldn't find any way to go ahead.
You should know by now to give more information !
However in your case it could well be a driver issue especially if it is a clone board.
Hello, I continue to get this error. USB device not recognized
I have explored many sites, on Microsoft, Hows.tech, Wikihow and many others. Not helpful
My USB device was not detected.
Do I need to install any form of hotfix mentioned in this Guide Method 2
Please provide more details.
Board type ?
Link to where you got your board ?
OS ?
USB port type ?
Bob.
