Try this. I think the problem was not quite correct usage of { & }.
Test of RTC DS1307 via I2C.
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Day of the week, and
Year with Leap-Year
56 bytes battery backed RAM
Square Wave Output, can connect to INT2/D6 or PD7
Modified to Run thru IDE Serial port
#include <Wire.h>
//variables
byte seconds_address = 0x00;
byte seconds; // bit 7 = Clock Halt, Enabled = 0, Halt = 1
// bits 6-5-3 = tens of seconds 0-6, bits 3-2-1-0 = units of seconds, 0-9
byte minutes_address = 0x01;
byte minutes; // bits 6-5-4 = tens of minutes, bits 3-2-1-0 = units of minutes
byte hours_address = 0x02;
byte hours; // 7=0. 6 = 1 for 12 hr, 0 for 24 hr.
// bit 5: 12 hr mode = AM(0)/PM(1). 24 hr mode = upper tens of hrs
// bit 4 = lower tens of hrs, bits 3-2-1-0 = units of hours (0-9)
byte day_week_address = 0x03;
byte day_week = 0; // range 01-07
byte date_month_address = 0x04;
byte date_month = 0; // range 01-31
byte month_address = 0x05;
byte month = 0; // range 01-12
byte year_address = 0x06;
int year = 0; // upper byte 0-9, lower byte 0-9
byte square_address = 0x07;
byte sqwe = 0; // square wave enable
// Out-0-0-Sqwe-0-0-RS1-RS0
// Out, Sqwe = 0/0 - Square wave output = 0
// Out, Sqwe = 1/0 - Square wave output = 1
// Out, Sqwe = 0/1 or 1/1 - Square wave output per RS1/RS0
// RS1/RS0 = 00 = 1 Hz
// RS1/RSo = 01 = 4 KHz
// RS1/RS0 = 10 = 8 KHz
// RS1/RS0 = 11 = 32 KHz
byte RTC_ram_address = 0x08; //range = 08-63, 0x08-0x3F
int RTC_address = 0x68; // 1101 000
byte incomingCommand = 0;
byte RTC_write_command = 0;
byte RTC_read_command = 0;
byte RTC_ram_command = 0;
// use F0xx, F1xx,F2xx, F3xx, F4xx, F5xx, F6xx, F7xx
// to send one register write commands
// use E0xx to read registers back - not coded yet
// use C0xx to read RAM back - not coded yet
byte incomingRegister = 0;
byte RTC_register = 0;
byte incomingData1 = 0;
byte incomingData2 = 0;
byte new_data = 0;
byte outgoingData = 0;
int delay_time = 100;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
unsigned long duration = 5000;
Wire.begin(); // no address, we are master
Serial.begin (57600);
Serial.flush();
currentMillis = millis();
if (Serial.available() >3){
incomingCommand = Serial.read();
incomingRegister = Serial.read();
incomingData1 = Serial.read();
incomingData1 = incomingData1 - 0x30; // convert ASCII to HEX
incomingData2 = Serial.read();
incomingData2 = incomingData2 - 0x30; // convert ASCII to HEX
new_data = (incomingData1 << 4) + incomingData2; // put the Upper/Lower nibbles together
Serial.print ("command ");
Serial.println (incomingCommand);
Serial.print ("register ");
Serial.println(incomingRegister);
Serial.print ("data1 ");
Serial.println (incomingData1, HEX);
Serial.print ("data2 ");
Serial.println (incomingData2, HEX);
Serial.print ("combined data ");
Serial.println (new_data, HEX);
if ((incomingCommand == 'F') | (incomingCommand == 'f')){
incomingCommand = 'F';
if ((incomingCommand == 'E') | (incomingCommand == 'e')){
incomingCommand = 'E'; // or whatever you decide to go with
switch (incomingCommand) {
case 'F':
Serial.println (" Sending a command ");
switch (incomingRegister){
case '0': // write seconds
Serial.println ("Seconds ");
Wire.beginTransmission(RTC_address); // select device
Wire.send(seconds_address); // queue the register
Wire.send(new_data); // queue data
Wire.endTransmission(); // send it
delay (delay_time);
break;
case '8': // write RAM
Serial.print ("RAM ");
Serial.println (RTC_register, HEX);
Wire.send(RTC_ram_address); // queue the register
delay (delay_time);
break;
incomingCommand = 0; // reset for next pass
} // end switch:case RTC_register for command 'F
break; // end command 'F'
case 'E':
Serial.println (" Sending Command ");
case '0': // read seconds
Serial.println ("Seconds: ");
Wire.requestFrom(RTC_address,1); // (device address, R/W) R=1, W=0
seconds = Wire.receive(); // read the data here
Serial.println(seconds, HEX);
delay (delay_time);
break;
case '8': // read RAM
delay (delay_time);
break;
} // end switch:case RTC_register for command 'E'
break; // end command 'E'
if ( (currentMillis - previousMillis) >= duration){
previousMillis = currentMillis;
// Reset the register pointer
Wire.send(0x00);
Wire.requestFrom(RTC_address,8 );
minutes = Wire.receive();
hours = Wire.receive();
day_week = Wire.receive();
date_month = Wire.receive();
year = Wire.receive();
sqwe = Wire.receive();
// Seconds
// Hours
Serial.print ("Hrs " );
Serial.print (hours, HEX);
Serial.print (" Mins ");
Serial.print (minutes, HEX);
Serial.print (" Secs ");
Serial.print (seconds, HEX);
Serial.print (" Day ");
Serial.print (day_week, HEX);
Serial.print (" Date ");
Serial.print (date_month, HEX);
Serial.print (" Month ");
Serial.print (month, HEX);
Serial.print (" Year 20");
Serial.print (year, HEX);
Serial.print (" Square Wave ");
Serial.println (sqwe, HEX);
