How to hard wire a USB cable directly to arduino?
How can I connect the USB cable wires directly to arduino pins so that I can send and receive data without any loss? How to connect the "Data+ and Data-" wires of USB to arduino? Is this possible?
I'm a beginner with arduino!
Thank you.
Clearly an XY problem. You should not be having any data loss over USB so the solution is to find the cause of the data loss and fix it instead of doing some insane soldering project.
To answer your original question. It would be extremely difficult and require advanced soldering skills. The resulting connection would be fairly fragile. You could glue the wire to the board to provide some strain relief for the solder connection, but you would still need to be very careful not to yank on the USB cable.
pert:
Thanks for your reply.
The thing I need to know is that to which arduino pins I will connect the Data +ve and Data -ve wires of USB cable.
Which Arduino board are you using?
Its Arduino Uno.
They are not on any of the Arduino pins broken out on the headers on your board. The USB data pins are on the small black chip that's near to the USB jack (either a ATmega16U2 or a CH340). The Uno actually makes access to these pins much easier than the newer boards with the surface mount USB jacks. The USB pins are exposed on the bottom of the board under the USB jack:
The above diagram is the top view of the board, so it will be mirrored if you're looking at the bottom side of the board.
So you could tack the USB cable wires on to those solder points.
It still doesn't change the fact that this should not be necessary. The only reason I can imagine you would have a problem with data loss over USB that would be solved by doing this is if you have a defective USB cable (in which case you should just replace the cable) or if you have a bad USB jack (in which case it might be reasonable, but I've never seen one of those type B jacks go bad, even on Arduino boards I've abused almost daily for 7 years).
Thank you. Let me give it a try.
How do you know that the data loss is due to bad USB and not bad serial receive code?
Probably read about it on the Internet! :astonished:
I smell a “my arduino isn’t working” topic in the works and smoke...
Well, the original question is clearly completely nonsensical, but
akhilanil:
apparently explains it! :astonished:
