I've imported a library to the Online Editor, however when I try to include the library, I get this error message: /tmp/086242753/MenuTest/MenuTest.ino:2:27: fatal error: DS3231_Simple.h: No such file or directory
I went through the same process with the LiquidCrystal_I2C.h library, and it is working fine. Any ideas what I'm doing wrong with the DS3231_Simple.h library?
Edited to add:
OS: Windows 10 64bit
Browser: Firefox 62.0.3 (64-bit)
Board: Uno
Desktop IDE: none
I imported that library and compiled a sketch that included it and I didn't get any error. However, this problem has been reported by several other people recently.
If you can't find a solution, the workaround would be to use the standard Arduino IDE, which you can download here:
I used the zip that you attached. I did use Chrome. I normally use Firefox but I have the NoScript extension installed in Firefox and it causes problems with Arduino Web Editor even when it's whitelisted so I can't use Arduino Web Editor in Firefox.
I switched to Chrome, deleted the library, re-imported it, re-included it, and I'm still getting the "No such file or directory" error at compile.
Worried that it might be something to do with my sketch, I tried creating a new sketch and including the library; same error persists.
Any other ideas? As mentioned, I know I can work around this by installing the desktop IDE, but it would be nice to be able to get this working on the Online Editor.
I don't regularly use the Arduino Web Editor so I'm not an expert in troubleshooting it. Someone else with more experience might come along with an answer.
Until then, my advice is to look at the other recent posts in this forum section and perhaps the Chrome App section too: http://forum.arduino.cc/index.php?board=112.0
to see if anyone else with the spurious "No such file or directory" error has found a solution.
I've attached for You one of the library ZIPs that I imported to the Web Editor Libraries, which works fine in Arduino IDE.
Any ideas to solve that problem please???
This is a different bug from the original one reported in this thread. For further discussion, please use one of the dedicated threads for this specific bug:
