Hy All,
Currently, I am doing an architectural project on the TU Delft and for the first time ever I'm investigating the possibilities of electronics (Arduino) to create interactive architecture. The project that I am doing involves creating an urban furniture with interactive elements. The concept is to have multiple LDR sensors detect the movement of people by integrating them into the surface and then have the values translate into a certain color of light. The color of light will give feedback to the user about how crowded it is (or how high the density of users is). Since we will make a small 1 to 1 prototype I don't need hundreds of sensors nor LEDs, but I would like to use, let's say 5 RGB LEDs in combination with 10 or so LDR sensors.
I've purchased the Arduino MEGA since it has 15 PWM pins, which would in theory suit 5 RGB LEDs just fine. But because I can't find any examples of this I'm a little bit worried that it is not that easy. So, can I, without problem hookup 5 RGB LEDs to the Arduino MEGA?
- I did some research and noticed that creating more PWM pins on a standard Arduino by SoftWrite will cause problems when there is a delay in the code (which there will in my case).
- Secondly, I would like to avoid having to use an RGB strip, since I want more control on the placements of the LEDs. (The same goes for an LED matrix or NEO-pixel.
- If possible I also want to avoid having to use something like a multiplexing chip, I'm a little bit worried that I would make things overly complicated. But of course, if I have no other option then please tell.
- I've seen a lot of examples using transistors, can I avoid them with just 5 RGB LEDs? If not, which one should I use?
This is the list of parts I have at my disposal, as of now:
- Arduino MEGA
- 10 RGB LEDs common cathode (I already found that this would make thing complicated if I would use a multiplexer since most of these are sinking devices.)
- 10 LDR sensors
- Jumper wires (all kinds)
- multiple 1K resistors
- multiple 10K resistors
- multiple 220 resistors
- some 220k resistors
- Breadboard (both small and large)
Currently my setup uses 5 LDR sensors and 2 RGB LEDs (on a normal Arduino), it works just fine, but now, how would I expand my RGB LEDs the best way?
And this is my current code:
int LDRpin1 = A1;
int LDRpin2 = A2;
int LDRpin3 = A3;
int LDRpin4 = A4;
int LDRpin5 = A5;
int LDRvalue1 = 1;
int LDRvalue2 = 2;
int LDRvalue3 = 3;
int LDRvalue4 = 4;
int LDRvalue5 = 5;
int BlueLED = 9;
int GreenLED = 10;
int RedLED = 11;
int BlueLED2 = 3;
int GreenLED2 = 5;
int RedLED2 = 6;
pinMode(BlueLED, OUTPUT);
pinMode(GreenLED, OUTPUT);
pinMode(RedLED, OUTPUT);
pinMode(BlueLED2, OUTPUT);
pinMode(GreenLED2, OUTPUT);
pinMode(RedLED2, OUTPUT);
int LDRpin1 = analogRead(A1);
int LDRpin2 = analogRead(A2);
int LDRpin3 = analogRead(A3);
int LDRpin4 = analogRead(A4);
int LDRpin5 = analogRead(A5);
LDRvalue1 = analogRead(LDRpin1);
delay (100);
Serial.print("Value LDR1 = ");
Serial.println(LDRvalue1);
int color = map(LDRvalue1, 0, 1023, 0, 255);
Serial.print("value Map1 = ");
Serial.println(color);
LDRvalue2 = analogRead(LDRpin2);
delay (100);
Serial.print("Value LDR2 = ");
Serial.println(LDRvalue2);
int color2 = map(LDRvalue2, 0, 1023, 0, 255);
Serial.print("value Map2 = ");
Serial.println(color2);
LDRvalue3 = analogRead(LDRpin3);
delay (100);
Serial.print("Value LDR3 = ");
Serial.println(LDRvalue3);
int color3 = map(LDRvalue3, 0, 1023, 0, 255);
Serial.print("value Map3 = ");
LDRvalue4 = analogRead(LDRpin4);
delay (100);
Serial.print("Value LDR4 = ");
Serial.println(LDRvalue4);
int color4 = map(LDRvalue4, 0, 1023, 0, 255);
Serial.print("value Map4 = ");
Serial.println(color4);
LDRvalue5 = analogRead(LDRpin5);
delay (100);
Serial.print("Value LDR5 = ");
Serial.println(LDRvalue5);
int color5 = map(LDRvalue5, 0, 1023, 0, 255);
Serial.print("value Map5 = ");
Serial.println(color5);
if((LDRvalue1 >= 500) and (LDRvalue2 >= 500) and (LDRvalue3 >= 500) and (LDRvalue4 >= 500) and (LDRvalue5 >= 500))
analogWrite(GreenLED, 0);
analogWrite(BlueLED, 10);
analogWrite(RedLED, 0);
analogWrite(GreenLED2, 0);
analogWrite(BlueLED2, 10);
analogWrite(RedLED2, 0);
if((LDRvalue1 <= 500) and (LDRvalue2 <= 500) and (LDRvalue3 <= 500) and (LDRvalue4 <= 500) and (LDRvalue5 <= 500))
analogWrite(BlueLED, 0);
analogWrite(RedLED, 50);
analogWrite(BlueLED2, 0);
analogWrite(RedLED2, 50);
delay(200);
delay(200);
Thanks in advance!
Edwin
