Hello All,
Arduino IDE is crashing on Mac after upgrading to Yosemite.
I was using version 1.0.6.
Any suggestion how to fix it ?
Any body else having similar issue ?
Thanks
Hello All,
Thanks
Having this same problem. The only error I'm finding is this
10/14/14 12:00:43.632 PM com.apple.xpc.launchd[1]: (cc.arduino.Arduino.111076[6582]) Service exited with abnormal code: 1
It appears that you need to install the "JavaForOSX2014-001" update. I think it installs a v6.0 of Java.
My update OSX to 10.10 Yosemite on my IMAC 27in 2012 late version had issues until I updated JAVA to JDK 8u25 for OSX and installed IDE 1.5.8 for JAVA 7
All is good now loading and working with my UNOs, Megas, Minis, and Nanos, including able to load to my DUE finally
I also cannot get 1.06 to work, but 1.5.8 works fine. I also had to instal the correct driver VCP Drivers - FTDI
Which you have already done.
1.0.6 does not appear to work at all now.
This worked for me. Installing legacy Java 6 found here.
http://support.apple.com/kb/DL1572
The answer I found from here.
http://forum.arduino.cc/index.php?topic=273175.0
My Uno was not working with yosemite.Downloaded this and problem solved.
Here is the instalation file from Apple for old version of Java
http://support.apple.com/kb/DL1572?viewlocale=en_US&locale=en_US
