avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x31
HOw to solve it or what s the problem
Which Arduino board are you using?
make sure you don't have wires in pins 1 and 0, these are used for communication.
aljazcernigoj:
How to solve it or what s the problem
Beginning with a search over that most asked topic here?
SCNR...
its for 3d printer cr 10s it just doesnt load on it
Please do this:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 143428 bytes (56%) of program storage space. Maximum is 253952 bytes.
Global variables use 6239 bytes (76%) of dynamic memory, leaving 1953 bytes for local variables. Maximum is 8192 bytes.
Low memory available, stability problems may occur.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\Primoz\AppData\Local\Temp\arduino_build_212871/Marlin.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
I did this its port4
In file included from sketch\fastio_1281.h:34:0,
from sketch\fastio.h:54,
from sketch\fastio_AT90USB.h:35,
from sketch\fastio.h:52,
from sketch\fastio_1280.h:34,
from sketch\fastio.h:50,
from sketch\fastio_168.h:34,
from sketch\fastio.h:46,
from sketch\MarlinConfig.h:26,
from C:\PTC\Aljaž\Nova mapa (3)\Nova mapa\CR-10S E3Dv6 Marlin-1.1.8\Marlin\Marlin.ino:31:
fastio.h:320:2: error: #endif without #if
#endif // _FASTIO_ARDUINO_H
In file included from sketch\fastio_AT90USB.h:35:0,
In file included from sketch\fastio_1280.h:34:0,
In file included from sketch\fastio_168.h:34:0,
In file included from sketch\fastio_644.h:34:0,
from sketch\fastio.h:48,
In file included from sketch\MarlinConfig.h:26:0,
exit status 1
#endif without #if
what about that?
It looks like you messed something up when you were setting up the configuration of Marlin.
