I had some trouble with some of the examples for the MS4525DO pressure sensor. I modified the code and have no trouble with the code below. Tested on a Leonardo. I only read pressure, not temperature. I included a sensor definition section near the top of my code so several versions of the MS4525 can be used.
I used this part for a Raspberry Pi project here: PyFly HAT-ish Board
Feel free to use this code without any restrictions.
// File MS4525_Test
// A Arduino program to test the operation of pressure sensors in the TE Connectivity MS4525D series (I2C versions only)
// Written: 7/9/2019
// Rev.: 1.00
// Changes: First release back to the community. Started with bits of code downloaded from the Arduino forums.
// The sensor specific characteristics are setup with constants in the beginning of the program.
// The device page is https://www.te.com/usa-en/product-CAT-BLPS0002.html
// The device data sheet can be found at https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+SheetMS4525DOB10pdfEnglishENG_DS_MS4525DO_B10.pdfCAT-BLPS0002
#include <Wire.h> // Arduino I2C library
#include <stdint.h> // Standard C, Allows explicit data type declaration.
// MS4525D sensor characteristics (from the 4/2019 version of the data sheet)
// MS4525D sensor I2C address (uncomment the Interface Type of the device you are using)
// Interface Type I
const uint8_t MS4525DAddress = 0x28;
// Interface Type J
//const uint8_t MS4525DAddress = 0x36;
// Interface Type K
//const uint8_t MS4525DAddress = 0x46;
// Interface Type 0
//const uint8_t MS4525DAddress = 0x48;
// MS4525D sensor full scale range and units
const int16_t MS4525FullScaleRange = 1; // 1 psi
//const int16_t MS4525FullScaleRange = 0.0689476; // 1 psi in Bar
//const int16_t MS4525FullScaleRange = 6895; // 1 psi in Pascal
//const int16_t MS4525FullScaleRange = 2; // 2 psi
//const int16_t MS4525FullScaleRange = 5; // 5 psi
// MS4525D Sensor type (A or B) comment out the wrong type assignments
// Type A (10% to 90%)
const int16_t MS4525MinScaleCounts = 1638;
const int16_t MS4525FullScaleCounts = 14746;
// Type B (5% to 95%)
//const int16_t MS4525MinScaleCounts = 819;
//const int16_t MS4525FullScaleCounts = 15563;
const int16_t MS4525Span=MS4525FullScaleCounts-MS4525MinScaleCounts;
//MS4525D sensor pressure style, differential or otherwise. Comment out the wrong one.
//Differential
const int16_t MS4525ZeroCounts=(MS4525MinScaleCounts+MS4525FullScaleCounts)/2;
// Absolute, Gauge
//const int16_t MS4525ZeroCounts=MS4525MinScaleCounts;
// end of MS4525D sensor characteristics
// fetch_pressure is a function to do the I2C read and extraction of the three data fields
byte fetch_pressure(uint16_t &P_dat, uint16_t &T_dat)
byte _status;
byte Press_H;
byte Press_L;
byte Temp_H;
byte Temp_L;
Wire.requestFrom(MS4525DAddress, static_cast<uint8_t>(4), static_cast<uint8_t>(true)); //Request 4 bytes, 2 pressure/status and 2 temperature
Press_H = Wire.read();
Press_L = Wire.read();
Temp_H = Wire.read();
Temp_L = Wire.read();
_status = (Press_H >> 6) & 0x03;
Press_H = Press_H & 0x3f;
P_dat = (((uint16_t)Press_H) << 8) | Press_L;
Temp_L = (Temp_L >> 5);
T_dat = (((uint16_t)Temp_H) << 3) | Temp_L;
return _status;
// setup is the main function to setup the diagnostic serial port and the I2C port
Wire.begin();
// wait until serial port opens for native USB devices
while (! Serial)
delay(1);
Serial.println("MS4525DO test");
byte _status; // A two bit field indicating the status of the I2C read
uint16_t P_dat; // 14 bit pressure data
uint16_t T_dat; // 11 bit temperature data
float psi;
_status = fetch_pressure(P_dat, T_dat);
switch (_status)
case 0:
//Serial.println("Ok ");
case 1:
Serial.println("Busy");
case 2:
Serial.println("Slate");
default:
Serial.println("Error");
psi=(static_cast(static_cast<int16_t>(P_dat)-MS4525ZeroCounts))/static_cast(MS4525Span)*static_cast(MS4525FullScaleRange);
Serial.print("psi:");
Serial.println(psi);
Good luck.
