Topic: After the Mega 256, what is the next most powerful Arduino board? (Read 3097 times) previous topic - next topic
bbqq
Hello, I have been using the Mega 256 but I don't use all the pins. What is the next most powerful board that offers "just a little bit" fewer pins but smaller in size?
sterretje
https://www.arduino.cc/en/Main/Products.
Take your pick, Zero might fit the bill.
Or look at https://www.pjrc.com/teensy/
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
GolamMostafa
What is the next most powerful board ..
Two Questions:
1.  What is the accepted definition of a most powerful board?
2.  Do you have your own (if any) definition of a most powerful board?
DrAzzy
If you want to stay in AVR-land, there's no official board between the Uno and the Mega2560. There are unofficial boards (with good support via hansibul's core) with the ATmega1284p, and I think the ATmega2561 with more pins than the atmega328p but fewer than the 2560.
There are also all the "faster" arduinos like the Zero and other SAM based boards. These are pretty well supported, and can do computations faster, but they're 3.3v (so you need level shifting to interface with 5v stuff) and the library support isn't quite as good.
Word of terminology: "powerful" is ambiguous - most poeple take it to mean processing speed, not number of pins. A mega2560 is actually ever so slightly slower than a 328p, due to differences in certain instructions to support the larger flash address space.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
outsider
Wonder why Atmel didn't step the AVR architecture up to 16 bit (databus) instead of "leaping" to 32 bit  ARMs?
DrAzzy
Isn't that xmega? They didn't take off the way the atmega line did, as far as I can tell.
outsider
