hi
try checking the physical connection & electrical continuity between the Arduino and stepper. Sometimes a bad solder joint makes a connection look OK when it isn't. Also make sure you have a ground connected between the Arduino and the stepper.
You could also try putting a voltmeter on the Arduino pin in question, to see if it is actually going high/low according to the code.
D
