Hello.
First of all, im new here !
Ill try to explain my problem :
Ive got Arduino 2560 Mega since 2013 . I make a few sketch for it .
Yesterday, i get it again and i cant upload. The trace say timeout error, comunication with programmer error
Ill search in this forum fix for this problem and ive seen that there are a few people that have the same problems. Ive read fixes for "!!!" problem, a strange fix that consist in push reset button when my sketch is going to upload, but any fix of this work.
I change PC and get the same response. I change the cable too, and the same response
I think maybe i need to use other bootloader or programmer but ill try diferent options.
Any ideas?
if any need some information, i can give it ,
Thank you
Mario
Check the port if it is visible in IDE and working. And also, make sure that IDE setting is correct: programmer, board, port.
Post the log from IDE and try to describe the behavior of on-board LEDs.
Budvar10:
Thakyou for your reply.
The port is visible in IDE. Programmer and board are corrects . When i try to upload blink , L led turn on, and RX led turn on only when i get timeout at debugger.
This is the trace :
LOG:
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.elf" "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019\\sketch\\Blink.ino.cpp.o" "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/core\\core.a" "-LC:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.elf" "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.elf" "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\it3\\AppData\\Local\\Temp\\arduino_build_398019/Blink.ino.elf"
Sketch uses 1460 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM6 -b115200 -D -Uflash:w:C:\Users\it3\AppData\Local\Temp\arduino_build_398019/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
When the upload process start the L should flicker (3x) and then Tx should blink as it receives data. Normally the Rx blinks at response little less as Tx during write phase and vice versa during read/verify phase.
Post detailed log from uploading. Switch on it in the Preferences. Please, use code tags for posting log: [</>] button.
About loopback : Ill try to do it, and i dont get echo response .
About genuine or clone : I dont know really but i think is clone.
Ide : ive got 1.8.7 but ill try with 1.0 and 1.6 and no result.
Log : I dont know what you refer with detailed log. Ill have enable verbose at upload and compile : (Thats the same )
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM5 -b115200 -D -Uflash:w:C:\Users\msua9\AppData\Local\Temp\arduino_build_61385/Blink.ino.hex:i
Using Port : COM5
I have same problem. Arduino stays with L Led Blinking and not blinking TX or RX.
When try to upload any sketch I get this error:
Arduino is visible from my laptop on COM3 as "COM3 (Arduino/Genuino Mega or Mega 2560)"
Another Arduino Mega is visible at COM5 with same identification
I tried to burn bootloader but not works, I tried from Arduino Mega (new one) as ISP to
Arduino Mega.
I tried to connect PIN10 to Reset
And another 5 pins from ICSP
And on programmer connected a capacitor from RESET to GND.
Can any says what is the problem with this boards??
Any says how to wiring Arduino Mega to Arduino mega to burn bootloader, only I found how to wiring from Arduino ONE to MEGA or MEGA to ONE.
My sketch is MARLIN 2 to my 3D Printer and found this error when Stepper not working, but 3D printer and can manage menu from LCD but when try to connect to laptop pronterface not connect to Arduino....
Make sure you really did all steps correctly. Try it again. If there is no response, then the problem is on-board usb/serial programmer and it is not good. It is hard to repair and probably better to buy new board.
Yes, I using original sketch, but all examples that I found are Programmer Mega2560 to Target Arduino Uno.
But, I not found any example where is using Programmer Mega2560 to Target Arduino Mega2560.
I tried also, using PINs 50,51 and 52 as MISO, MOSI and SCK but does not work too.
From Wrong Mega:
System wide configuration file is "C:\Users\FNS\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM3
avrdude: ser_open(): can't set com-state for "\\.\COM3"
avrdude: ser_drain(): read error: Controlador no válido.
el puerto seleccionado
no existe o tu placa no esta conectada
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: Controlador no válido.
No, these 3 are surely correct as in #9.
Wiring on the picture looks correctly connected but if you are trying other than -cstk500v1, 10uF capacitor is needed between RESET and GND on the source (programmer) board.
Yes, I see the capacitor. Not clear which pins from the photo but I hope that RESET and GND with + on RESET.
All FF in response means usually short circuit or missing clock but simply bad wiring as well as "all zero response". The only advice for now is: check your wiring again. It is quite simple. Connections between ICSP connectors are 1:1 except of RESET. The RESET on target is connected to pin 10 on source. You can use DMM or LED with resistor in series (~1kOhm) on target between VCC and RESET, to indicate reset pulse passing to the target. Must blink once at beginning of uploading process. Make sure your wires are good and have good contact with pins on connectors.
