There are broken links on the webpage https://www.arduino.cc/en/Hacking/DFUProgramming8U2
Under the headings:
"Download updated firmware"
"If your board is Arduino UNO R1 "
"Reset the 8u2 or 16u2 "
there are links to images and firmware that just give a 404 error.
pert
March 25, 2019, 11:58pm
2
Thanks for reporting these issues!
Last year, I reported the broken link to the updated firmware (as well as other issues on that page) here:
opened 10:36AM - 27 May 18 UTC
Component: Documentation
Type: Bug
Change:
>Updating t… he Atmega8U2 and 16U2 on an Uno or Mega2560 using DFU
To:
>Updating the **ATmega8U2** and 16U2 on an Uno or **Mega 2560** using DFU
Change:
>Previous versions of the Uno and Mega2560 had an Atmega8U2.
To:
>Previous versions of the Uno and **Mega 2560** had an **ATmega8U2**.
Change:
>Here's how to update the firmware on your 16u2 in a few steps.
To:
>Here's how to update the firmware on your **ATmega16U2** in a few steps.
Change:
>The Arduino Uno and Mega 2560 have been shipping with the updated version of the ATmega16u2 firmware.
To:
>The Arduino Uno and Mega 2560 have been shipping with the updated version of the **ATmega16U2** firmware.
Change:
>Windows: Download Atmel's flip programmer from here
To:
>Windows: Download Atmel's **FLIP** programmer from here
Change:
>Linux: from a command line type
To:
>Linux: **From** a command line type
Change:
>The firmware is also located with the Arduino software in the /hardware/arduino/firmwares/arduino-usbserial folder.
To:
>The firmware is also located with the Arduino software in the **/hardware/arduino/avr/firmwares/arduino-usbserial** folder.
Change:
To:
>Reset the **ATmega8U2** or **16U2**
Change:
>To verify you have reset the 8u2 or 16u2 chip:
To:
>To verify you have reset the **ATmega8U2** or **16U2** chip:
Change:
>In the Arduino programming environment, check the list of serial ports.
To:
>In the Arduino **IDE**, check the list of serial ports **under Tools > Port**.
Change:
>Windows: use flip to upload the hex file to your board
To:
>Windows: **Use** **FLIP** to upload the hex file to your board
Change:
>Mac & Linux: from a terminal window,
To:
>Mac & Linux: **From** a terminal window,
Change:
>If your board has an atmega8u2 type atmega8u2
To:
>If your board has an **ATmega8U2** type atmega8u2
Change:
>You can check this by looking in the serial port menu of the Arduino software.
To:
>You can check this by looking in the **Tools > Port** menu of the Arduino software.
Change:
>The 8u2 and 16u2's flexibility allows for other firmware
To:
>The **ATmega8U2** and **16U2**'s flexibility allows for other firmware
Change:
>Turn you Arduino Uno into a PS3 compatible USB joystick
To:
>Turn **your** Arduino Uno into a PS3 compatible USB joystick
The broken images seems to have happened in only the last day or two, I've noticed it on quite a few of the pages on this website. If you would like to report the missing images issue, the best place to do it is by opening an issue report here:
pert
March 25, 2019, 11:59pm
3
I forgot to mention that if you need the firmware, it is now located here:
pert
March 27, 2019, 8:36am
4
The issue of the broken images has now been reported:
opened 05:47PM - 26 Mar 19 UTC
closed 04:04AM - 29 Mar 19 UTC
Component: Website
As I wanted to read three tutorials from the website, I noticed that all … the images where missing (404).
The 3 pages are :
- <https://www.arduino.cc/en/Main/Standalone>
- <https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard>
- <https://www.arduino.cc/en/Tutorial/ArduinoISP>
But it seems they are not the only ones.
Can you please make the images available again ?
Thanks.
Hopefully it will be resolved soon.
