Hi guys,
I'm using an SD card with my UNO and its successfully writing temperature and time/date data to the card in a CSV file.
I'm also using a 433MHz RF card which is connected to the UNO using software Serial, the RF card transmits the card data to another UNO which is connected to a PC, allowing me to view the data on the SD card on the terminal.
When using software serial, I have a problem where the data is sometimes garbled up in the wrong order, this only happens when I transmit the entire contents of the card, which could be 50 records or so.
It doesn't happen on hardware serial, I have the BAUD set a 9600.
Is there a way I can correct the issue, using the software serial, I am using the new software serial and not the old original one.
Thanks guys
