I have paired two Hc05 modules for my project.For testing purpose I have connected initially a pushbutton to slave and led to master and I am able to control the led using pushbutton via Blueotth.
Now I have connected a LDR(Light dependant Resistors) to slave which will be communicating to master connected to 0.96'' OLED . The OLED should be displaying the values of LDR
Slave code:
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(10, 11); // RX | TX
#define ldrPin A0
int state = 20;
int ldrValue = 0;
char ldr;
pinMode(9, OUTPUT); // this pin will pull the HC-05 pin 34 (key pin) HIGH to switch module to AT mode
digitalWrite(9, HIGH);
pinMode(ldrPin, OUTPUT);
BTSerial.begin(9600);
ldrValue = analogRead(A0);
BTSerial.write(ldrValue);
delay(10);
Master code :
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
int state = 0;
#define OLED_RESET 4 // not used / nicht genutzt bei diesem Display
Adafruit_SSD1306 display(OLED_RESET);
char inChar;
String string;
pinMode(13, OUTPUT);
// initialize with the I2C addr 0x3C / mit I2C-Adresse 0x3c initialisieren
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
delay(2000);
display.clearDisplay();
display.setTextColor(INVERSE);
if(BTSerial.available() > 0)
{ // Checks whether data is comming from the serial port
state = BTSerial.read(); // Reads the data from the serial port
display.setCursor(30,0);
display.setTextSize(1);
display.print("LDR Reading:");
display.setCursor(30,10);
display.setTextSize(2);
display.print(state);
delay(10);
display.display();
But I am unable to get the complete reading . The OLED shows readings as 0,1,2,3 (single digits fluctuating randomly.
Serial.write() just sends a byte as a binary value. Sending data in human readable form with .print() makes debugging much easier. I would only use .write() if I had no choice because I needed the extra performance.
#define ldrPin A0
int state = 20;
int ldrValue = 0;
char ldr;
BTSerial.println(ldrValue);
delay(10);
Master code :
#include <SPI.h>
#include <Wire.h>
int state = 0;
char inChar;
String string;
display.display();
delay(2000);
delay(10);
display.display();
Normally what goes on in the code has no effect on the compiler - unless it detects an error. I can't try compiling your code because I don't have the Adafruit libraries.
The Arduino IDE is written in Java and occasionally the Java code finds something it does not like - probably because the Arduino creators forgot to handle an exception. The stuff it does not like is usually due to a typo so go through your code VERY carefully.
I have not checked carefully to see if you have mucked up my function code - but I don't think you have. However, even if you had, it should not cause the compiler to hang.
Have you tried compiling my examples without any changes?
Rectified a small error. The program compiled without errors .
But the output on OLED showed random readings on 0,1,001,20,..etc. This is not the correct readings of LDR.
The example 2 of your link compiled without errors and it is showing correct readings in serial monitor. But it is not showing the correct reading after the modificaions. The slave code is as it is and the modification was in master code:
#include <SPI.h>
#include <Wire.h>
int state = 0;
char inChar;
String string;
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
display.display();
delay(2000);
recvWithEndMarker();
showNewData();
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (BTSerial.available() > 0 && newData == false) {
rc = BTSerial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData()
if (newData == true) {
display.print(receivedChars);
display.display();
newData = false;
My bad , I assigned LDR pin as output instead of input. Yes I modified the slave code to check whether it is sending correct reading or not on serial monitor.
Slave code:
#define ldrPin A0
int state = 20;
int ldrValue = 0;
pinMode(ldrPin, INPUT);
ldrValue = analogRead(ldrPin);
delay(10);
The serial monitor showed the correct readings.
Now I changed master code to get readingson serial monitor. Master code:
// Example 2 - Receive with an end-marker
Serial.println("<Arduino is ready>");
showNewData();
void recvWithEndMarker() {
char rc;
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
void showNewData() {
Serial.print("This just in ... ");
Serial.println(receivedChars);
delay(10);
newData = false;
But her the Serial monitor is just showing
<Arduino is ready>
The readings of LDR changes from 0 to 1023. I tried changing numChars from 32 to 128 . Still the serial monitor showed no readings.
What can be possibly wrong here? Initially it was showing some readings when I wrongly assigned LDRpin as output instead of input. Now after correcting it , it is not showing any value.
Yes the connection are correct. Initially I was able to control a LED connected to master from a pushbutton connected to slave. The connections of modules were unchanged. Instead of pushbutton , LDR is connected to slave for input and instead of LED , an OLED is connected to master for output.
vishruth_kumar:
I can't make any sense of that. You know a whole lot more about your project than we do.
Make a simple drawing showing how you have everything connected and post a photo of the drawing. Please DO NOT use Fritzing.
Slave part :
Ldr and hc05 module is connected to Arduino Uno. The ldr will be taking the readings and communicating it to Arduino through analog pin (A0) .
Master part :
The hc05 module is connected to Arduino nano. It'll be getting readings from slave and display the same on serial monitor. Once I get the readings on serial monitor , I'll connect OLED to Arduino nano to display the readings .
Following the same connections with slave code as:
#define ldrPin A0
int state = 20;
int ldrValue = 0;
delay(10);
and master code as:
const byte numChars = 1024;
showNewData();
char rc;
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
newData = false;
I am getting the readings in serial monitor of master as:
<Arduino is ready>
This just in ... 8
This just in ... 3
This just in ... 4
This just in ... 3
This just in ... 3
This just in ... 3
This just in ... 3
This just in ... 4
This just in ... 3
This just in ... 4
This just in ... 3
This just in ... 3
and so on. The problem might be with the code Can you please check?
Oh come on dont leave me hanging!!
I followed every step. The serial monitor of master is showing the first digit , but it is correct. How can I receive the exact readings . There must be slight modifications in the functions in the Example 2 of your link.
I am a beginner in arduino , So I am not able to understand. Please help me!
Sorry. I forgot about you - I was distracted by trying to build a model railway locomotive.
My guess is that your master program is actually showing what it receives. If it was not receiving anything it would not print anything.
Debugging should always focus on simplicity. Rather than sending the value from the LDR why not just send a fixed value - for example BTSerial.println("1234");
Also, you are sending values very frequently - 100 times per second. For testing slow that down to 2 per second.
In your slave program you are printing the value to the Serial monitor - is that showing the same thing as the master is receiving?
In the direction of simplicity it would also be a good idea to remove the Bluetooth devices and connect the two Arduinos by wires (and GND) using the same pins as are used by the Bluetooth devices.
