Dear Programmers
i am trying to connect two of p4 rgb led matrix 32x64 together with arduino mega but the same data appears in both.
i need to display data separated.
can you help me.
after make search i found that you can display data separated at the same lines.
regards
Post your code, using code tags please. Instructions are in the forum guide. If the code is too long to post, please make a short sketch that illustrates the problem.
But your diagram only shows the Arduino wired to one display. Are the two displays being chained or is the connection to both displays common?
Note:lib that i used RGB-matrix-Panel-master.
So according to the guide lines in How to use this forum which you no doubt will have read before making a post here, then you should supply links to obscure libraries.
