I'm using a 5k pot as an angle sensor for a robor arm joint, but I'm getting unstable readings (+- 2)
Software averaging is ok, but I would need to do it in hardware. Is this the best that can be done, or can I improve it somehow, by adding some capacitors (which ones) or perhaps using a lower resistance potentiometer?
The accuracy of the ADC of the ATMega chips is already +- 2. Also, the linearity of an inexpensive potentiometer is around 5%. I don't think you can improve what you have.
If you need more accurate values you would need to move to an optical encoder.
Analog read is 0 to 1023. You can use "map" and convert the reading to 0 to 360 degrees. You would get 3 times the less sensitivity or in a way it would seem like the potentiometer was 3 times more accurate because the noise would not show up as much.
If your scaling was 0 - 180 the effect would be even larger.
http://arduino.cc/en/Reference/Map
Chargin & cyclegadget
Thank you very much for your answers. I'll settle for this accuracy, and will use optical encoders for the next project.
Best
amatic
you can use multiple readings and average them
value = 0;
for (int i=0; i< 16; i++) value += analogRead();
value /= 16;
or use a lowpass filter
value = value - 0.1 * (value-analogRead()); // same as value = 0.9 * value + 0.1 * analogRead(); but optimized.
Difference the lowpass filter makes the system less responsive, and only needs one analogRead().
I think Chargin & cyclegadget are confusing accuracy and stability.
The normal stability for any A/D converter can only ever be +/- 1 so at a stability of +/- 2 there is room for improvement.
Yes a capacitor would help damp down any noise pickup. A 0.1uF across the wiper of the pot and ground will help. As will a software solution like that filter above.
@Rob Tillaart
Yes, I am using the lowpass filter as a software stabiliser.
@GrumpyMike
Thank you, I will try the 0.1uF capacitor.
