Arduino Forum
Using Arduino => Motors, Mechanics, Power and CNC => Topic started by: eslamshash on May 29, 2012, 04:02 pm
Title: need help to reverse the direction of a brushless motor
Post by: eslamshash on May 29, 2012, 04:02 pm
Is it possible to reverse the direction of  a brushless motor with Arduino?
Title: Re: need help to reverse the direction of a brushless motor
Post by: robtillaart on May 29, 2012, 05:00 pm
check this tutorial - http://itp.nyu.edu/physcomp/Labs/DCMotorControl  -
Post by: Chagrin on May 29, 2012, 05:38 pm
Brushless motor, rob.
eslamshash, is this a three phase DC motor or an AC motor? We need a better description.
Post by: JimboZA on May 29, 2012, 05:55 pm
Just yesterday I tried to run a laptop cooling fan backwards by hooking the battery up back-to-front, and it didn't start.
Do brushless DC motors actually even run backwards?
Jim
Post by: robtillaart on May 29, 2012, 09:36 pm
oops  :smiley-red:
Post by: Chagrin on May 29, 2012, 10:52 pm
A brushless fan as found in a computer contains the controller within the fan and that controller is only designed to spin the fan in one direction. Fundamentally though, brushless DC motors are certainly reversible.
FWIW there are zillions of RC cars with brushless motors and reverse capability.
Post by: retrolefty on May 29, 2012, 10:52 pm
best if you posted about a specific motor, but most classic 3 phase DC (and 3 phase AC motors) can be reversed by simply reversing any two of the three wires.
Post by: JimboZA on May 30, 2012, 05:04 am
Thanks- what what I expected. Or, at least I would have been surprised if they couldn't run both ways, and thought there might be something in the motor preventing it. I wonder why though?- the plug is made to fit one way only, and since the fan is hidden inside it's not likely to get connected back to front in use.
Post by: terryking228 on May 30, 2012, 07:44 am
I suppose it's possible to reverse two of the 3 wires in a small brushless motor, with tiny reed relays or Fets. But is it worth it??
Also, the timing of the hall effect rotation sensor is sometimes optimized for one direction, I believe.
A few years ago someone was using a 4 inch fan that was reversed to control the draft on a wood stove, but I bet that was a brush type motor.
How about mount two identical fans in opposite directions and turn on one or the other??
Post by: Zapro on Jun 10, 2012, 02:56 pm
Jim
Inside a computer fan is a control IC - it's actually a small computer with state machine and all. This switches 3 coils on the motor, making the magnet ring turn. For feedback there is sometimes some hall-sensors too. Usually all this circuitry is built in a single component with 3 to 5 legs soldered to a small circuit board. Reversing the polarity on the wires would be like putting in power to the Arduino in reverse - you wouldn't want to do that - right ?!
There is no way of reversing the fan direction without modifying it heavily - and then the fan blades do not work in reverse - look at the profile on them, fan blades and propellers only work the "right way" round.
Post by: JimboZA on Jun 10, 2012, 03:42 pm
@Zapro, yes I know the blade only works in the correct direction- I was just experimenting with reversing the fan motor because I had one and couldn't find a normal DC "toy" motor.  :)
But I'm curious as to why they bother with the control electronics- buried inside a laptop where it won't get fiddled with under normal circumstances, and with a plug that prevents reverse polarity in the first place, it seems a lot of trouble or expense to go to.
Post by: Zapro on Jun 10, 2012, 03:49 pm
They use brushless motors because they is more silent, and there is no brushes to wear out.
// Per.
Post by: kf2qd on Jun 10, 2012, 04:02 pm
Answer to both questions comes back to the folks doing the assembly. They are poorly paid labor in some place like China, or worse, who are given minimal training and have to assemble as many of these as possible in as short a time as possible. It is cheaper to make sure the unskilled labor can do it right the first time so someone else doesn't have to rework it. And there are less customers complaining about the fan not working.
Post by: doctortk on Feb 19, 2013, 07:07 am
Brushless DC motor requires a control circuit in order to work.  The control circuit for PC fan can be made so small it easily fits inside the motor.  You can find details on how a brushless DC motor works in this excellent article from Giorgos Lazaridis.
http://pcbheaven.com/wikipages/How_Brushless_Motors_Work/
Post by: michinyon on Feb 19, 2013, 02:26 pm
Take the fan out, turn the whole thing over,  and screw it back on the other way.
